The cd player in my 2005 subaru outback will not play or eject all that comes up on the scren is error99
  • 2,071 Answers
Need to clean and resoldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Good luck:
Posted on Jul 25, 2008
Clutch slipping on 20005 subaru outback
Do you have any free play in your clutch pedal? The pedal should move at least 1" before you feel resistance. If you have free play then you probably have a clutch going bad. If there is no free play then you need a clutch adjustment.
Jan 05, 2012 | 2005 Subaru Outback
Cd's stuck in 6-stacker
If the CD magazine does no release then it is needed to remove the player and open the mechanism to remove the struck up cd or mechanism.
Now is is possible that some CD can warp over a period of time or it can also get caught up in the transfer mechanism. Also if the loading mechanism had encountered a fault it can jam the system, so after removing the cover you can assist the cd to eject out with manual leverage of the motor and mechanical linkages. If not there is fault in the drive of the loading motor.
Sep 02, 2011 | 2005 Subaru Outback
My cd-player says "ERROR99" and will nor play or
my factory dvd player reads error any solutions i have 2005 dodge caravan
Apr 06, 2011 | Car Audio & Video
Cd in dash changer has jammed and now cd's won't eject or go into play mode
I don't know if the unit has lost power? does it light up still? if so then the carriage has dislodged from the load tracks, a compitent electrician can reset them unless the load motor has burnt in it, then it will be cheaper to replace the unit. If this is the case, sit down at the table one night with pliers and screwdrivers and have a play at dismantling it to retrieve your cds, sounds like fun? Good luck
Nov 20, 2009 | 2005 Subaru Outback
Stuck Cd in 2003 Subaru Legacy Outback
pull out the fuse for your radio and turn the ignition to the on position and wait 10 secs. Then turn off the ignition, replace the fuse and turn to the on again. It may work as I've done this to other cars which have had cd's stuck
Sep 18, 2009 | 2003 Subaru Outback
2007 Subaru Impreza, the 6 CD changer will not play CDs and the display reads "Push Eject", but when I do push eject the cd is not ejected. None of the CDs will eject and none will play.The manual says I...
are there any cd's with homemade labels ,how many cd's are loaded?the dealer will recommend to remove the radio and send out for repair costing you a couple hundo or more depending on the problem if you're out of warranty,you'll also be out a radio until its repaired,if your factory warranty is still in they will just order an exchage unit and call you for install when it arrives. hope this helps,good luck!
Jul 12, 2009 | 2005 Subaru Forester
CD Changer is stuck
drop the faceplate, there should be a tiny hole you can push a paper clip in. push in a little bit and it should eject. good luck
Nov 30, 2008 | 2005 Subaru Outback
152 people viewed this question
 Grubhead
Grubhead
