Question about Whirlpool Dryers
My dryer is about 10 years old. I had a belt replaced last year and currently it has stopped working. When I open the door the light comes on but when I press the start button I get nothing. My husband has replaced the fuses but it made no difference. I am pondering wether to call a repair man and spend the money on a service call or put the money toward a new dryer. Any advice? Kendra
  • 868 Answers
My dryer is about 10 - 102610f.jpgHave you checked the Thermal fuse?It is also a good idea to check your door switch and the wires coming from it because they sometimes hang into the tub and wear out.
Posted on Jul 22, 2008
Started then stop and wont come back on. circuit breakers checked, all wiring checked, door closed. light on inside on, could the start stop switch be defective?? dryer is about 10 years old. DRYER...
yes could be start /stop microswitch...firstly make sure fuse ok in plug also feed ok lastly ensure post to operate door switch has not broken off........hope this lot helps.....
Jan 14, 2011 | Dryers
Whirlpool Dryer needs a push on inside of drum to get started, by overriding the door closed switch. The electronic starter will not work, unless the door is open and it's given a push to engage...then I...
yes and some other parts that from long time of usage need to be replace as well.
If you want this machine to keep work for more years ...fix it :)
I have Appliances Repair company and I prefere to fix old machine and see them working for many years then new one that not last for long... what is your model # i tell you what parts to replace...
Jan 05, 2010 | Maytag Dryers
Stopped running. Can't start.
You probably have a clogged vent. If the moist air can't vent to outside your dry times would be much longer and the heat would get trapped in the dryer. This probably caused your thermal fuse to fail. Once that fails the dryer won't do anything. The good news is that it should be a fairly inexpensive repair.
Dec 09, 2009 | Dryers
Siemens Condensor Dryer E46-38. After a few
Mine is 4 years old and the pump went within 8 months! The dryer has had 6 new pumps in total! It was last fixed 6 months ago and now playing up again! I dont even constantly use my dryer! I am very disappointed with Siemens now, my last dryer lasted me 10 years and it was constantly on the go when my children were young! Here comes, tomorrow I have got to book another repair! No more Siemens for me.
Oct 20, 2009 | Siemens Dryers
What would make a dryer stop tumbling? It is about ten years old now. It turns on alright but just won't spin anymore. Its a MayTag so shouldn't it work forever! LOL
Probably just a broken belt. Unplug the dryer and open it up (PIX BELOW) clean out the dryer and inspect the wheels idler and blower cage.The belt is probably gone after 10 years. Here are some repair pix
Aug 28, 2009 | Dryers
I have a 10 year old Maytag Performa. It started
Hello, try checking the door switch, with no light in the drum it points to the door switch being bad. To test this unplug the machine, bypass the door switch with a wirenut..Don't forget to replace the switch if bad, the door switch is there for a reason. Good Luck!!! Please feel free to comment again if you have any other questions or concerns. Mike
Jul 23, 2009 | Maytag Dryers
15 year old Kenmore dryer not working
Sounds like you thru the breaker. If not, it is the door switch.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Feb 11, 2008 | Refrigerators
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
