LGLXA1230 Air Conditioner Logo
Posted on Feb 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My AC 1200BTU work in heating 5min. and than stopped
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Feb 07, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953415
Points
6173
Check temp setting and also room sensor. Setting must be minimum 3 degree more than room temp. Check continuity for sensor. If open replace it. Check coil , air filter and heater element are cleaned.
If high amps, replace heating element. Thanks.
Ac runs for about 5min then trips breaker
call the technician to check the current draw for the unit
could be a start/run capacitor or compressor going out
What ever you need to know the current draw before anything
I have 2003 CORROLA 1.6 VVTI T3, DASBOARD, AC NOT WORKING
seems? (why guess?) (fuses are black/white deal)
3 non related systems failed, hummmmm
check fuses with a walfart $10 meter, on low OHMS> Rx1.
  1. 0 ohms is good
  2. infinity is bad.
fuses that look good, can in fact be bad. (hair line cracks)
so test them and avoid, SEEMS?
Rear glass heater is a hot wire heater.
if it has 12vdc to the wire and no heat the grid is bad (open)
if no 12v there, then the relay/fuse or switch to it is bad,
the voltmeter finds this in 5min work.
Hazard not working (but are blinkers> dead? on either sided?)
again fuses.
Dash board dead, (cluster) FUSES.
A.C. not working (the FSM and alldata.com cover this)
1: fuse , check fuese
2: if heater fan is dead, so will be AC.
3: A/C clutch not engaging for 6 reasons , ask. for list of tests.
all tests are in the FSM. BTW.
my wild guess, is you are working on car that has not run
right for a long time? accumulated, issues?
Heat and ac stopped working in 05 kia sedona
check that the heater control (tap ) is being turned on by the controls.. Have an accredited ac mechanic check the ac system .
1200btu kenmore air conditioner with heat no heat
your heating element could be out. Is this a heat pump type or a heating element?
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
92 f150 5.0 i changed the computor and now it will not idle in park
Clean throttle body...clean idle air control valve...disconnect battery 5min. reconnect battery...let idle...all lights/ac off 5min.
Dryer runs for about 5min (has heat ) then stops, error code E1
usually that means you have a bad thermistor.
try setting it to low heat timed dry
how long does it run?
Whirlpool gas dryer. Only few min.( less than 5min) heat work.
there is a thermal fuse inside the dryer it is a one time fuse also there is an ignitor that could be bad
15helpful
3answers
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
