Question about Car Audio & Video
4 subs and two amps
That's fine I will try that. how should the RCA coming off of the sub woofer output from the radio go into the amp? Split one female to two male adapters and then what, which side should it go to after that?
    Novelist:
  • 100 Answers
I'm not that familiar with the insignia line but If the amps have an "input" and an "output" for the RCAs then run the RCAs in one, Then hook the output of that one to the input of the other. I did this with my 2 memphis 500Ds and it worked great. It also looks better than a couple of splitters, but yes You would just get two splitters with all female connections on them so you can plug 2 sets of RCAs into the one set. Also it doesn't really matter how you hook the RCAs up unless you are going for stereo sound then you would need to make sure the rights are hooked up together and the lefts are hooked up together. I hope I could help.
-Andrew Hawkins
Posted on Jul 23, 2008
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
I have a clarion m 309 radio and I'm trying to hook up a fusion FM 402 amp for a sub woofer. I had all speakers playing but, I could not control the volume of the sub with the radio. I need to know...
Amps usually receive their signal through RCA wires. Your radio should have one pair of RCA outputs on the back. (red and white) You will adjust your subwoofer volume by adjusting the gains on the amplifer (little knob next to the RCA inputs of the amp), then you can turn up the bass on your radio.
Sep 06, 2011 | Clarion Car Audio & Video
Im not sure which plugs I should plug my RCA cables that come from my amp to the reciever. I dont know if its the "back RCA output" or the "Front RCA output" or the "subwoofer...
First of all get yourself a Y-LINK cable. (single male RCA on one side/ double female RCA on the other side) Connect the Y-LINK to your head unit sub woofer output with the stereo RCA that leads to the sub woofer amplifier. Now you are connected to the correct output. I do not know what head unit you had connected before to base your comparison, however there is a output voltage difference from one head unit to another, (1.2V, 2V, 2.5V, 4V, 5V) and that is what determines where the gain on the amplifier should be set to. Always match the headunit output voltage with the amplifier gain control to be the same. It is not uncommon for some entry level units to have a single sub woofer output. dreamsystems
Feb 21, 2011 | Pyle PLTS77DU Car DVD Player
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....http://www.poweracoustik.com/pa2006/manual%20and%20catalog/Processors/PWM-20.pdf
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Still no sub woofer output
SET THE CROSSOVER TO "L.P.F."POSITION AND SELECT THE LOWEST FREQUENCY AS THE CROSSOVER POINT.
[AN AMPLIFIER IS SUPPOSED TO "AMPLIFY"(TO INCREASE)ANY OUTPUT.]
TRY CHANGING THE POLARITY OF WIRES FROM AMPLIFIER TO SPEAKERS /SUBWOOFER.{it leads to cancellation of bass output.}
if u still have doubt contact me again.
May 26, 2008 | Alpine CDE-7856 CD Player
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
