Question about Sony SDM-HS73P 17" LCD Monitor
No display cpu working properly but monitor having no display power light of monitor is turned on orange
  • 1 more comment
  • Anonymous Aug 03, 2008
    my video seven l19wa goes blank power light stays on orange
  • JVDECLUE Nov 13, 2008
    my monitor died i removed the back i have voltage into the power board but no power out thx jed
  • kb108904 Dec 29, 2008
    it may not be a inverter problem if your light is orange, if when you turn it on it says "no signal going to power save" then it is not the inverter because you can see the message. i am having the same problem with my sony sdm-hs73, and through my research the problem seems to be coming from the video/controller board. i dont know where to find one of these to replace my bad one though. any help would be apreciated.
    Champion:
  • 293 Answers
Hi...there,
It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it.
Posted on Oct 15, 2008
  • 813 Answers
Open your cpu remove ram clean it & put it back
Posted on Jul 22, 2008
Lenovo K330B ideacentre K Bios/ bootup problem
It sounds like your monitor is not getting data from the computer. Check the cable from the computer to your monitor. Does it stay in tight on both ends? Have you tried a different data cable?
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 28, 2014 | Computers & Internet
Why has my monitor turned orange. model dylm19r6 computer monitor
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Jul 14, 2014 | Soyo Computers & Internet
Monitor will not turn on and power light blinks blue
Good luck.
Jul 10, 2014 | Sylvania Scm2401 Curtis Lcd Monitor 24"...
Blinking on/off light.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 06, 2014 | ViewSonic VA1913w Monitor
Today I received a faulty Monitor Dell E773c, the problem is that the Monitor get On and the power LED is Green and after remove VGA Cable from CPU it get Orange, But no Display (The Screen is Blank)
To get monitor work for you, you should connect the VGA cable to CPU. When you remove the VGA cable, monitor has got nothing to display so it goes in stand by mode with orange LED on.
Sep 15, 2013 | Dell Computers & Internet
When i turn it on it only appears only a second , my monitor turn black
Hello Chelleydiao, hi, its either you have a CPU problem or the monitor itself. Check or use another monitor to see if the problem is fix. you see an blank monitor can also be caused by the CPU if it fails to boot. the aid the checking, do you see any orange light on the monitor? or any indication.... the led light on the screen in summary: green or blue means there is power and the CPU boots up. if orange the CPU fails to boot, if there are no lights on the Monitor panels, there are problems on the monitor. check these first....I need a much detail description.
Dec 18, 2010 | AOC Monitor
Just today when watching a movie my monitor will go blank and the light at the bottom which is white when on will go dark and then turn orange like it's been turned off then about 20-30 seconds later it...
When the power saving options of the computer is turned on, after particular time the signal stops to the monitor and the orange light will come on, once you move the mouse or press keys on the keyboard, the cpu comes back from the power saving mode, the signal passes on to the monitor and there will be display.
Sep 05, 2010 | Acer H233H bmid Monitor
Powers on then back off in two seconds...I don't know how to open the case without destroying it..
hello,
Seems that your problem is not your Samsung Monitor. Please check very well. Since this is basically an indication that your CPU is not working that is why there is no display in the monitor and the yellow light turns to orange.
  1. Please try to use another monitor if you still have one that is working well. Then power up your computer and see if there is display on the monitor. If there is, then your reported monitor really has a problem. And if there is no display even in the new working monitor, then the CPU is in frozen state that is why there is no display on the monitor.
May 08, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
I just purchased a new cpu and plugged in my Acer X203H monitor that i have only had for around 3 months and when I turn on the computer and monitor, the monitor power light flashes orange and blue and has...
Sounds like your PC is diplaying out of your monitors range. Try pressing f8 while booting up to get safe mode. then turn down the video resolution to display what your monitor can handle. Good Luck.
Nov 20, 2009 | Acer X203H bd Monitor
Sony SDM-HS73P 17" LCD Monitor Logo
250 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
