Question about Samsung Audio Players & Recorders
Missing speaker wire for Samsung HTSK5 reciever
  • 2,071 Answers
I agree what the comment of JUSUS,or if you can't follow up the wire from where you buy,Just buy wire number #18....
hope this may help;
DON'T FORGET TO RATE;
Posted on Jul 25, 2008
  • 57 Answers
Check the nearest best buy I am sure you can fine compatible wire that will fit. Or any music store such as Sam Ash music store I am 99.9 percent sure you can find it to Sam Ash music store.
Good luck
Posted on Jul 23, 2008
I bought a Samsung 65 in flatscreen and the power button on the bottom is gone just wires hanging out will that stop the TV from coming on with the remote.
The missing power button you have on the bottom of your TV is just a manual On and Off switch in case your remote does not work, it has nothing to do with the remote signals at all. Most TV's have a tiny little window or sensor in the front panel which recieves the IR signal from your remote, most IR recievers on TV's have a dark red little window as the sensor.
Feb 23, 2015 | Samsung Televison & Video
How do i connect my reciver to my lcd hdtv so the audio is coming from my speakers not the tv speakers.
kindly get four audio RF connection wires look for the audio output on the front or back of your tv. one of the output connection is white the other is red.look for the same connectors on your reciever the same colour.but they are marked input.plug the output wires from your tv to the input connection of your reciever.if you have separate speakers, connect the speaker wires from the output connectors of your reciever so you can get sound comming from your tv through your reciever,good luck.
Sep 25, 2011 | LG Televison & Video
Can I hook these directly to my TV
No. The jacks on the back of your tv are line level. That means no power. To get the power, you need a reciever. Red and white RCA wires will go from your tv's out and the other end to an input on your reciever, and your speaker will be wired to the speaker out jacks on your reciever.
Nov 14, 2010 | Jensen JP1200 Main / Stereo Speaker
When i turn power on it came on and says protect then turn off..please help
The reason why this is happening is because the reciever is going into protection mode due to a short circuit to the amplifier. It might be a speaker that is shorted out internally or there might be some speaker wires making contact with each other at the back of the reciever or at the speaker. The first thing I would do is disconnect all the speaker wires from the back of the reciever(make sure to label them before removing so you know how they go back). After removing the speaker wires turn on the reciever and see if it goes into protection mode. If it does then there is a good possibility that the internal amplifier might have a short. If it does not go into protection mode then that is good because there is more than likely a short on one of the speaker wires or speaker itself. Now connect one set of speaker wires at a time. After you connect each one try turning on the reciever until it goes into protection mode again. When it does you will have your culprit. Then try swapping speakers with that problem wire set and see if it still does it. If it does then it could just be the wires but also switch the wires to verify that the amplifier does not have a bad channel. If swapping both the wires and the speaker swapping produces the protection mode then that channel for the amplifier will be defective. I hope I have not confused you too much.
Aug 17, 2010 | Audio Players & Recorders
Bose acoustimass 15
you might need a reciever for starts thats usually the main factor needed it should all come together after that
Jun 02, 2010 | Bose Acoustimass 15 System
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
How do i get the protect off my reciever
You have a 'PROTECT' message? Try disconnecting all the speakers. If it is still there with no speakers connected, then the problem is internal. If it goes out then the problem was a short speaker wire or shorted speaker, connect one at a time to find the defective one.
Mar 22, 2010 | Samsung HT-Z310T Theater System
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Samsung reciever sound issues
I am having the same problem... I would like to hear from anyone with a solution or at least a reason!
Dec 29, 2009 | Samsung Audio Players & Recorders
95 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
