Question about Teac Reference DR-H300
TEAC DH 300 can't get HDMI to work, something to do with " all" settings.
I had the same problem until I connected it to a TV. Then you can enter setup and activate HDMI that is not by default !
Posted on Jan 16, 2009
I have the same problem. I have connected it to Philips TV, but there is no signal. I cannot even enter setup on Teac. The SETUP button is not simply working. Can anybody help? Please!
Posted on Nov 08, 2008
What is the code for a teac set top box model hdb850
Codes are in the remote. If you are using a TEAC remote with a TEAC STB, you may be able to find something that will work.
Jul 16, 2016 | Teac Televison & Video
I want to turn my TV onto high definition for gaming. How do I do that. I have looked in the menu but cant see an option for the high definition. I just bought a Teac LEV32A1HD. Cheers.
Well, that depends on what you are using for your gaming. If you are using something like a Nintendo 3DS, a PS4, an Xbox One, an Xbox 360, or a PS3 there should be RCA connectors (3 - red, white, and yellow) or on the higher end consoles even an HDMI port, simply plug the cables into the corresponding female connectors on the console and on the back of your TEAC. If you have an HDMI output on your console, get an HDMI cable and plug that in (your TEAC has 3HDMI ports).
Once you have done this, take the TV remote and click "Setup." This will take you to the "Source" screen. In the 3rd section down, you should see HDMI1, HDMI2, HDMI3, and PC. The choice you make here depends on which HDMI port you used for gaming. Choose that one and click the "OK" button on your remote. If you hooked it up correctly, you should see something on the screen relating to your gaming console. If you do, then start playing your game!
If you don't want to or can't use the HDMI ports, your other option is to use the RCA ports. These are colored, usually, red, white, and a third color. Plug the red and white connectors into the corresponding connectors and place the last color (yellow, green, etc.) into the last connector. Follow the above Setup procedure except for choosing the Input. In this case, I believe you should choose the YPbPr input.
If you are using a computer for gaming, you must use an HDMI port. The Setup procedure is the same for setting up a gaming console.
Happy gaming!
Oct 17, 2014 | Audio Players & Recorders
HDMI port not sending signal to TV from laptop
check with different hdmi monitor or check the tv with another hdmi device
Jul 16, 2017 | Acer Computers & Internet
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Mar 03, 2017 | Onkyo HT-S3300 Theater System
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
On the door display it says " ER DH " what does
I found this to be quite up your alley... gives you possibilities for DIY repair.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Apr 13, 2011 | Kenmore Elite 44723SS Commercial...
I'm trying to hook up using 2 little rca speakers, for L/R i've set the reciver to 2 speaker setup and for some reason i can't get sound from my speakers. any ideas? I've got HDMI from a Samsung DVD player...
If the amplifier supplies a different resistance rating (ohms) than the speakers draw, it might automatically shut down the amplifier to protect from damage. Make sure the Teac output matches the speakers required input. Hooking up speakers that draw 8 ohms to an amp that supplies 2 ohms can cause amplifier damage.
Sep 28, 2009 | Teac DC-D2800 Shelf System
We cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Aug 24, 2009 | Televison & Video
Suddenly after 1 week of working OK The TEAC Micro Hi Fi System CX2001DAB decides to come up with "NO DISC" when inserting CD's Please help is this something simple that we are missing or is it a...
This indicates that the optics are not reading the disc. If this unit is indeed 1 week old, return it for a warranty exchange. Given its short life, insist on an exchange not a repair.
Dan
Sep 08, 2008 | Teac Audio Players & Recorders
Teac Reference DR-H300 Logo
577 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
