Question about Microsoft Excel for PC
Help How to add 15% to the existing value
    Problem Solver:
  • 4 Answers
In another column put in a formula (using the =) to multiply the current cell by 1.15. For example if your current values are in column A, then in the first cell in, say, column B put in the formula =A1*1.15, then copy this down the spreadsheet using the + in the bottom right hand corner of the cell border.
If you particularly want the final values back in the original column then highlight the new column (arrow at the top of the column), copy, highlight old column and select paste special - value.
Posted on Jul 22, 2008
    Sergeant:
    Champion:
  • 214 Answers
Go to page setup and under scaling you can adjust to your required percentage
You can convert this in a number different of ways, all giving the same result if applied properly. However people from the olden days that still used 8-bit computers often used following:
1.Split the binary number in groups of four digits, adding leading zeros if necessary. 11001100 => (1100) (1100).
2. Given the individual bits have values 8, 4, 2, 1 when set, convert the groups individually 1100 = 8+4 = 12. In your case, both groups have the same value,
3. Multiply the value for the left group by 16 and add the right group's value:12 * 16 + 12 = 192 + 12 = 204.
It helps if you know the multiples 1*16, 2*16, ...., 15*16 by heart.
Mar 22, 2014 | Office Equipment & Supplies
Tip
Hide/Unhide Logon Names
If you want to hide or unhide the names of users that are displayed on the initial logon screen:
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon \ SpecialAccounts \ UserList
  3. Add a DWORD with the name of the user account you want to hide
  4. Make sure it has a value of 0
  5. If there is an existing account, you can unhide it by giving it a value of 1
on Sep 20, 2010 | Computers & Internet
Tip
Add Your Own Windows Tips
Are you sick of seeing the same tips again and again when you first logon to Windows? Now you can change them to whatever you want, whether it's quotes, jokes or a to-do list, anything is possible.
Open your registry and find the key below.
HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ Explorer\ Tips
Create a new string valued named by incrementing the existing value names and set it to the required tip text.
on Jun 04, 2010 | Computers & Internet
Having troube with my FOREIGN KEYs on two tables.
I suggest you visit this website you will get the solution, I tried and it worked.
http://bit.ly/1bUVmuW
Nov 25, 2013 | Computers & Internet
I have a problem in my flash drive because i can save any files beacause it is write protected. what shoul i do to remove its write protection???
Hello Evitan,
From Start Menu >> Run, type regedit and this will open the registry editor. Navigate to the path below :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
If the registry key Storage DevicePolicies key does not exist, you will need to create it.
Download the batch file called add.bat from below link, and double click after download the key will be automatically added to registry.
http://www.troublefixers.com/wp-content/uploads/Miscellaneous/add.bat
Double click the key Write Protect in the right pane and set the value to 0 in the Value Data Box and press OK button. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.d set the value to 0 in the Value Data Box and press OK button
Aug 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
-3/5x-8 what is the value of x when y=-11
The following solution shows how to find the value of x:
Start with the general equation given:
y = -(3/5)x - 8
Substitute the known value of y:
-11 = -(3/5)x - 8
Add 8 to both sides:
-11 + 8 = -(3/5)x - 8 + 8
-3 = -(3/5)x
Now multiply both sides by 5 to get rid of the denominator:
-3 * 5 = -(3/5)x * 5
-15 = -3x
Now divide by -3 to get x:
-15/3 = -3x/3
x = 5
The answer is x = 5.
Apr 27, 2011 | Texas Instruments TI-84 Plus Calculator
How i can add a name and number in to existing contact list?
Nice try! Find an upper-class student to give you one-on-one tutoring with your homework.
Apr 08, 2009 | Google Android
Help..
Follow these steps to check for problems on the machine you cannot access.
1) Open the registry editor on the machine you cannot connect to by clicking on Start, Run
2) Type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following entries
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Services
Lanmanserver
Parameters
4) In the right-hand portion of the Registry Editor look for a key called IRPStackSize
5) If the key exists, double-click on it and increase the decimal value to 15 and click OK. Close the Registry Editor, reboot the computer and try to connect to the network share. If you are still unable to connect follow the above steps again and increase the decimal number for IRPStackSize by 5 and try again. Continue to do this until the stack size is large enough to permit access. Personally, I had to increase the number to 25 before I could connect. The decimal range for the parameter is between 11 and 50.
6) If the IRPStackSize key DOES NOT exist in the right-hand column of the registry editor, then click on right-click in the blank area in the right-hand column and choose New
7) Then Click on D-Word under the Key column
8) In the Name of the new key, type the name IRPStackSize and press Enter. Type the name with the correct capitalization as shown above.
9) Now double-click on the IRPStackSize key and type 15 in the value data box and place a dot next to Decimal then click Ok.
10) Close the registry editor and reboot the computer. Try to access the network share again. If the same error appears follow the steps above to increase the value and reboot again. Continue this procedure until the problem is resolved. The decimal range for the parameter is between 11 and 50.
Oct 18, 2008 | Computers & Internet
Powering up my computer
Hello there.
Your motherboard has 4x Serial ATA connections , as you are using 1 already this means you can add a total of 3 SATA new HDD to the system. Size doesn't really matter but thesedays you should be able to get good value for money on the 200-500GB version of the sata drives.
If you have windows installed already on the existing 40GB, then you can add the new HDD alongside the existing, then in Windows set up the new HDD as a new drive letter, giving you all the free space to save your files on.
Hope this helps.
Apr 15, 2008 | ASUS P4SP-MX Motherboard
Addition of two variable
In Actionscript 2.0 the output to the script below will be 15. Make sure that the values for the variables do not contain strings or extra characters like quotation marks. num1 = 5; num2 = 10; sum = num1 + num2; trace(sum);
Sep 28, 2007 | Macromedia Flash MX
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
