Question about HP LaserJet P2015dn Printer
TOP FIRST LIGHT IS CONTINUOUSLY BLINKING
With the above subject problem, I am unable to get print due to continue blinking of first light on the top of service icons. Actually I sent print command to the printer and due to electric failure page to be printed was in the begining of insertion area and after electric failure, I pulled back the page and after the light is on, this problem occurs.
  • Anonymous Jul 25, 2008
    Paper jammed.  Removed jam and now the printer will not reset so that it can print.
    Light stays on.  Tried clearing the memory, checking for paper pieces, on/off and nothing appears to help.
  • solonlee Sep 11, 2008
    Yup, and it happened right after i changed cartridges
Same problem starting this week, is there a reset? If so , how?
Posted on Jul 23, 2008
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Why does the blue light flash off and on continuosly"?"
Wayne,
I have attached a copy of the owner's manual. Page 6 in Safety section discusses why the light blinks. I hope it solves your blinking blue light issue.
PEACE http://www.sylvane.com/media/documents/products/airfree-onix-3000-air-purifier-owners-manual.pdf
May 24, 2014 | AirFree Onix 3000 Air Purifier
Lexmark e260d printer 4th light orange is continuously flashing. New toner cartridge was installed. Not printing
If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please contact Lexmark Technical Support
May 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
The printer light keeps on blinking continuously
goto control panel and click on printers or printer or faxes. when you open this folder your printer is shown double click on it and select all the previous print comands and if all comands will not removed switch off ur printer and the try again . and if the problem is same then unplug or plug ur usb data cable or if the problem can't be resolved the change ur data cable.
Jun 27, 2010 | HP DeskJet 3550 InkJet Printer
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
HP920c cartridge light wont stop blinking, printer wont print
Please refer below for detailed troubleshooting of the specific condition:
PRINT CARTRIDGE light RESUME light POWER light Blinking Off On c00106873.jpg c00106862.jpg c00106865.jpg Problem
The printer top cover is open, or there may be something wrong with the print cartridge.
Solution
  1. Close the printer top cover.
  2. If the PRINT CARTRIDGE light continues to blink, continue with the following steps:
    1. Open the top cover. The print cartridge cradle will move and then stop.
    2. Locate the yellow arrow on the top of the print cartridge cradle. The yellow arrow points to a drawing of a cartridge that represents a symptom. Perform the task associated with that symptom.
    3. For a list of symptoms, refer to How to use the cartridge drawings under the top access door on a 900 series Deskjet .
May 12, 2010 | HP DeskJet 920c InkJet Printer
TOP LIGHT ON PRINTER KEEPS BLINKING - I'M UNABLE
This should help you. It details what the blinking lights mean and should allow you to diagnose what the problem is.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061319&lc=en&cc=us&dlc=&product=305980
Oct 13, 2009 | HP DeskJet 5550 InkJet Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
HP LaserJet P2015dn Printer Logo
123 people viewed this question
Ben Johnson
