Question about Minolta EP1030/1030F CS/PRO Copier
Paper jams and c f 3 flashes
Minolta ep 1030 starts to make a copy but jams and displays c f 3
  • 25 Answers
CF3 - ATDC sensor malfuntion. This sensor measures the density between toner and developer. You might have a problem with too short developer. Add some more and do F8.
The manual says basically that you either have a problem with de sensor (under a bottom plastic plate of the image unit) or the main board (PWB-A).
Posted on Oct 31, 2008
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Mar 31, 2013 | Minolta EP1030/1030F CS/PRO Copier
My photo copier keeps saying pc ?
I worked on a EP 1030 copier and the error PC is when the machine doesn`t pickup paper. Make sure pickup roller is clean and there is paper in paper tray.
Mar 29, 2011 | Minolta EP1030/1030F CS/PRO Copier
My minolta ep 1030 is printing copies with a line down the page
Check the hot roller for a scratched surface. Otherwise you may have a bad photoconductor.
Jan 07, 2011 | Minolta EP1030/1030F CS/PRO Copier
Copier does not copy. Error message is
you have a paper jam somewhere inside the machine...
Dec 18, 2009 | Office Equipment & Supplies
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Jan 14, 2009 | Minolta EP1030/1030F CS/PRO Copier
Minolta EP 2010 copier, top loading doesn't pull paper
Hello sir; try to made 2 copies one go through by adf another one just put on the glass,if one copyclean another not clean then clean up the glass, if both copy all lines then replace drum unit.
Jan 06, 2009 | Office Equipment & Supplies
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta ep 1030
It is not actually a paper jam - when the copier detects a malfunction, it simply stops everything. Paper jams all have "J" codes (J1, J3, etc.).
A CF3 indicates a problem with the ATDC system (Automatic Toner Density Control). The output from the ATDC sensor is outside normal specs.
Possible causes would include the copier being run (and reset repeatedly) without toner, the imaging unit not being properly installed (or not present at all), use of toner not compatible with the unit, a defective ATDC sensor or (least likely) PWB-A.
Jul 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
201 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
