Question about HP Pavilion dv6000z Notebook
Display problem Hi , last week i got a hp dv6000 notebook and when i switched on i am not able to see anything on the screen but i am able to hear the processor runing and i tried to remove the battery and start working with AC then also i am not able to solve the problem i am a system admin i tired my best please suggest
    Scholar:
  • 81 Answers
Hi balas1980,
Check the memory. If it has multiple modules, then go thru the process of elimination to nail down the culprit. I had a similar issue just the other day.
Hope this helps and good luck.
Posted on Jul 25, 2008
Why computer is on, but screen want like up
Probably not what you want to 'hear', but this is the reason, and the solution,
http://www.youtube.com/watch?v=bnkQNmKauEc
A common problem for the HP Pavilion dv2000, dv6000, and dv9000 series of Notebook PC's.
The HP Pavilion dv6276us is part of the HP Pavilion dv6000 series.
Regards,
joecoolvette
(PS. I would use a Heatgun instead of a torch)
Nov 27, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
Hp pavillion laptop screen goes black
its the common problem with graphic card, if its nvedia chipset graphic, there is only one temp solution, ask any hardware machanics to put a glue and heat the display ic, then it would work for a week, in that period buy the amc from hp service centre, after a week if there is a prob, company will have to replacd the motherboard
Feb 10, 2010 | HP Pavilion dv6000t Notebook
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Display on HP DV6000 is scrambled.
Your problem is the screen itself, sounds like your graphics chip is fine by being able to use an external monitor. Change out the display, but also check the flat data cable on the back of the screen and make sure it just didn't slip out of the socket.
Oct 14, 2009 | HP Pavilion dv6000z Notebook
My hp laptop won't start.
This is more than likely whats going on
HP website says what to look for
"HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000."
Good luck..
Aug 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
One long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Blank screen
Hey Boots_Calara,
In most of hp/compaq dv6000 series that i have worked on have bad ram , easiest way is taking out the ram and replace it. Or if you have a friend that has a hp or compaq laptop switch the ram and try boot it with there ram. Try it before you replace the bad ram.
Jan 22, 2009 | HP Compaq Presario V6000T Notebook
Pavilion dv6000t screen won't come on.
I had this exact problem with a customers computer andi found out that HP put faulty motherboards in the DV6000, DV9000, Compaq V6000 Series Computers. Thankfully HP fixing all computers for free and extending the warranty even if the warranty has expired they will ship you a box and you ship it off and they fix it at no cost. the turn around period is about 7 days.
Here is a link to an article that talks about it
http://mattsblog.ca/2007/12/14/having-problems-with-your-hp-pavilion-dv6000-dv9000-or-presario-v6000-series-notebook/
Hope this helps!
NosirromNet
Dec 14, 2008 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Huge problem Please help me? cant see anything
Reset the laptop. Take out the battery and remove the power cable from the wall socket. Wait 30 seconds and put the battery back in, connect it back to the wall socket and start it up.
Jul 01, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
