Question about LG WD-14124RD Front Load Washer / Dryer
The front loading door gasket is torn, I asked for a replacement. Its 3 months since my complaint They say there are no spares sent from head Office. Also the swith panel is not working. There are
I have a 8/4 14124 R.D. The front loading washing and drying machine has its door gasket torn. I have placed innumerable complaints at your Indiranagar branch office, at Bangalore Also the switch on panel does not work. I have asked for replacement of the panel. Everytime they say the spares have not come from Delhi. Is there some way you could help me find replacement of the gasket and the switch panel. I have not been offered an Annual Maintenence contract. Please let me know if you have an Exchange offer for a neew machine if you are unable to provide the spares. I would appreciate an early reply for the replacements. Thanking you, Neiloo Prasad
  • neiloo Jul 22, 2008
    Master:
  • 382 Answers
Hello neiloo,
I know the response of LG service centre in Indra Nagar,Bangalore is pretty stagnant one..But I will suggest you speak to those service person quite STRONGLY asking your replacements because oonly after which they will be active for working on your replacement issue..As you say replacement i hope you have your warranty but if your willing to pay for service try the following link
http://yellowpages.sulekha.com/delhi/home-services/home-appliances-service/kalkaji/lg-it-service-centre.htm
Posted on Jul 22, 2008
  • Natesan Sabesan
    Natesan Sabesan Jul 22, 2008
    Hello again prasad,
    this is the address of the main service centre in delhi
    LG IT Service Centre
    #204, Shakuntala Building
    Shop #59
    Nehru Place
    Kalkaji
    Delhi - 110019
    Phone: 011-26280641, 26214369HOpe this helps you.......
    THank you!!
    Regards!!..
    Genius:
  • 2,785 Answers
Plz write a letter to banglore branch office,informing that you will drag them to consumer court and you will see the result very soon.
  • LG Master
  • 19,396 Answers
You need to address this to the customer support contact, please post here web address of the vendor and I will find the right contact..
Thanks
  • Ginko
    Ginko Jul 22, 2008
    I told you, where did you buy from?
    I hope you are reading my post, if yes then please provide an answer.
    If you bought from the Internet, then please provide web site name.
    Thanks
It leaks from the door how do i fix it? and is it expensive to fix?
The door gasket is most likely torn causing the leak. It costs about $110 plus labor if you are not handy enough to do the replacement. Indicate the exact model number of the washer for the exact replacement part number and detailed procedure on how to replace the door gasket.
Jun 08, 2010 | Maytag EPIC MFW9700S Front Load Washer
Torn door gasket / collar
It requires technical expertise and speccial tools. Part isn't expensive, labor may be depending upon where you live
May 05, 2010 | LG WD-14124RD Front Load Washer / Dryer
We discovered that our front door inner gasket is torn. Therefore, it's leaking during every load out of the door. I will be ordering the part but concerned that I won't be able to replace it. Do you...
If you've not done this before, expect to spend a lot of time. I've replaced these without disassembling the washer's front, but it's an arm-twisting experience to put the inner part of the gasket on, and to attach and tighten the clamp holding it. Haven't tried removing the front panel, if you can, do it - the job becomes much easier.
PS Check shocks and if the washer is leveled enough, door gaskets tear from excessive loads and excessive vibration.
Mar 29, 2010 | GE WBVH6240F Front Load Washer
Leaking water from underneath
The door connects to a round gasket called the "bellows". If it is torn, deformed or coming off water will leak underneath. Undo the 3 screws in the lower front panel and do an inspection of that area
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Torn front grey colored rubber seal, is this repairable?This rubber seal is covered with mold
These seals are not fun to replace for the average person. There will probably be a spring clamp around the front of the gasket which you can remove with a good pair of needle nose pliers. The back side will be held in with another spring or a screw clamp. If you install a new gasket just work from one side clockwise feeding it around the drum with your fingers. This can be a VERY frustrating process. If you have the extra money I would probably advise just calling a tech out. You will probably be looking at around 200 for the repair. Maybe more depending on the service call and labor.
To avoid the smell when you get a new gasket leave the door cracked between uses. You can also just run an empty load with bleach in it on the highest temp cycle with an extra rinse. (Basically highest heat longest cycle) Once a month.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Our gasket tore. How do you replace the gasket?
Its actually pretty easy.
1, Remove the top of the washer
2. Remove the screws behind the front panel with the knobs and buttons. set the whole assembly on top out of the way
3. remove the door of the hinge. there are 4 screws
4. remove the concrete weight
5. remove the back band folding gasket. It has a bolt.
6. remove the front band, its just under spring tension
6. replace gasket and install back band first.
7. work your way backwards from here.
Good luck
Scott
Jun 14, 2009 | GE WBVH6240F Front Load Washer
The rubber door gasket is torn, how to replace,
Get the model number off the washer
and go to appliance store who service or Sears
Jun 10, 2009 | GE WSXH208A Front Load Washer
My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-14124RD Front Load Washer / Dryer Logo
83 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
