Question about Dishwashers
Kenwood dishwasher keeps stopping with E4 fault code. have tipped to 45 degrees to release excess water and its ok for 2-3 washes, then repeats problem.
  • Anonymous Mar 15, 2014
    Machine stops a few seconds after it begins washing
    Scholar:
  • 93 Answers
Disconnect power to your dishwasher or unplug the power cord.for a few minutes. open up your control board check if water spilled on it. Dry the liquid. assemble it back. be careful not to mis fixed the harness wires.
plug back your power cord. do this solve your dishwasher.
Prince P
Posted on Jul 24, 2008
  • Femi Omojogberun Jul 25, 2008
    Follow this procedure, it might help: Do u sure the fault code is E4
    1. Disconnect the power to the unit
    2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
    3. Use a towel or a sponge to remove the water
    4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
    5. Test the dishwasher
    6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
    7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray: E4 code will appear
We have a belini dishwasher with E4 error code what shuld we do?
Hi, there is a few things that can cause the e4 code......
overdosing the machine can cause excessive foaming.adding soda crystals can also cause this (by clogging) or water pressure is to high.
turn off machine then tilt it backwards about 45 degrees (so it does not upset the water management system) and the water should drain away solving the error code.Hope this helps
Sep 22, 2012 | Office Equipment & Supplies
Constant beeping when switched on.E4 on programme
E4 would suggest a leak or spillage of water into the base of the appliance.- Unplug the appliance.
- Put some towels around the rear of it and tip it rearward about 45 degrees.
- Drain the water out of the base at the rear corners.
Once drained, try the machine again. If it fails very quickly then it would suggest a leak and you would need to drain it again, take the panels off and watch it working to locate the source of the leak. Cure the leak to stop the fault.
Hope this helps.
Aug 19, 2011 | Candy Dishwashers
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
Kenwood dish washer showing E4
Check the water inlet on the top of the dishwasher isn`t loose. It`s an easy fix if it is, just hold the inlet on top where the hose goes in and hand screw the plastic cap underneath thats inside the dishwasher. Mine done this and the water was pouring down from the top into the base, just follow the other tip for emptying the water from the base
Apr 23, 2010 | Kenwood KDW243A Builtin Dishwasher
Error code e4
This might be a re-badged generic dishwasher - on my Baumatic E4 error caused by floatswitch in bottom catch tray. Some (supposedly small amount) water collects here and should evaporate naturally. If it accumulates, float rises and stops machine.
TURN OFF THE POWER
try to find a way into the machine base catch-tray to sponge it out - on the Baumatic there are two large black plastic plugs on the front of the machine base that can be forcibly flipped out.
failing that, take machine out and tip it up to get rid of water
Oct 09, 2008 | Maytag Dishwashers
Kenwood kdw243a
The dishwasher still has water in it.  Lean dishwasher back at least 45 degrees and water should drain out through overflow pipe.  It could be caused by the dishwasher not being level.  Otherwise from reading reviews online it seems to be a common fault with this dishwasher and lots of people have returned and purchased different.
Sep 28, 2008 | Dishwashers
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
We have a kenwood kdw12st3a dishwasher - ever since we have had it, it has been nothing but trouble. It constantly flashes e4 so we have tipped it and drained the water out of the bottom (as advised) and...
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
Jun 30, 2008 | Dishwashers
I have a kenwood KDW12SL3A. The Drain got blocked at the dishwasher end, and I have now unblocked and tested the drainage but have still got an E4 error come up. how do I reset this?
Just got one of those at weekend and had e4 code-looked up on here and gor tis solutionwhich sems to work!
Jun 23, 2008 | Dishwashers
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
189 people viewed this question
Top Dishwashers Experts
