Question about JVC Car Audio & Video
My jvc -kd-g312 cd player will not switch on after my car battery went flat whislt I was on holiday. there is power to the unit because when I Press the select button four numbers apear on the screen. I have tried pressing the power button and the button next to it togeather buth this does not reset the cd raidio. can anyone help.
pnevai
  • 48 Answers
SOURCE: JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Posted on Jun 29, 2007
  • 7 Answers
SOURCE: DOESN'T WORK AFTER INSTALLING A NEW CAR BATTERY
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
Posted on May 28, 2008
sumthin
  • 71 Answers
SOURCE: have just installed (per instructions)
Hi colinelva.
I can probably help you but I need more info.
Lets start with the vehicle, What year ,? What specific model?, What type of head unit came out? Was it factory?
Did you use a wiring adapter, or just cut the plug off and hardwire it?. If so give me the color code of all the wires that you used in the dash. are their any left over but not hooked up? How many speakers? All Factory?
I don't need any info about the JVC Head unit.
Lets start with that, and we will take it from there.
Regards, Paul
Posted on Jun 13, 2008
marked
  • 6487 Answers
SOURCE: Need a User Manual for
You can call JVC for this concern so they can also provide you the user manual for that call this number 800‑252‑5722 Press 3.
Hope that helps.....
Posted on Jul 25, 2008
  • 55 Answers
SOURCE: JVC head unit problem
Do you have a "RESET" button on your stereo? Check your owner's manual to find it. I have a JVC unit in my car and the reset button is a small hole behind the detachable face. Take the end of a pencil or a pen and insert it in the tiny hole and hold for a few seconds. This should reset the stereo so you can get the CD out. Hope this helps...
Posted on Aug 30, 2008
JVC KD-G801 CD player has light on (on) button but doesnt switch on when pressed
Look for a pinhole button on the face, just left of the #1 radio preset. Use a ball point pen or paper clip to lightly hold this button for 2-3 seconds. You may do this with the key on. This will reset the radio's microprocessor.
Let me know if this helps.
Dec 18, 2013 | JVC KD-G801 CD Player
Jvc kd-bt11 will not turn on
Its is definitely the extra wire, i had this problem and took it to a shop the power wire has to be ran from the battery with a fuse in between them, you can find a live wire in the dash and splice and put a fuse between them, if you dont feel confident, i would take it to a local shop i did the same thing and they installed for 40$ but i had all of the hardware and the radio was already in the dash just needed power
Feb 20, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
Connecting Ipod to JVC KD-G312
according to
http://www.jvcmobile.co.uk/documents/installation_manuals/KD-G312_311.pdf
that's a cable for the steering wheel remote even though it looks just the same as an aux in
Oct 17, 2012 | Car Audio & Video
Newly installed in a camper from the leisure battery,power to the unit and will load the cd then the unit goes dead.Press the eject button and the unit illuminates and ejects and again goes dead
Do you have power going to both the red and yellow wires? The red wire generally goes to a switched power source and the yellow should be constant. Both wires need to have power going to them in order for the unit to work properly.
Nov 01, 2011 | JVC KD-S6060 CD Player
Jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Apr 25, 2010 | JVC KD-G110 CD Player
I have removed my JVC KD-G801 from my car but realised that there is still a CD inside the unit. How do I remove it?
Hook your power wires and ground up to a cordless drill battery , 12 volt, or 14 volt. Or use jumper wires from car battery. Hit eject. You don't need all the speakers etc hooked up.
Feb 13, 2010 | JVC KD-G801 CD Player
JVC KD-G230 will not work after my battery died
the battery probley shorted out your deck i think its time for a new one
Jan 11, 2010 | JVC KD-G230 CD Player
How do i remove a jvc cd receiver kd-g312
how do i remove a jvc cd kd/g312 reciever from my car
Feb 15, 2009 | Kenwood KDC-122 CD Player
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Mar 09, 2007 | JVC KD-S640 CD Player
Car Audio & Video Logo
35 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
