Question about Rancilio Silvia Espresso Machine
New Rancilio Silva - steamed milk not perfect
I have just got my Rancilio Silva machine, but I'm not satisfied with the steamed milk. I have been trying now for 3 weeks, but I feel the steamed milk gets watery.
I always let the machine stay on for 30 min before I start, when I turn the steambutton on, I empty the steamer for condensed water. I let the machine work until the mainlamb stop lightning, then empty the steamer again for a sec so there should me no condensed water into the steamer canals.
Still I feel it's a bit water into the milk when I finished. I have tried with all kinds of milk, from nofat (0,01%) to my favorite (4,6%). My old DeLongi machine made perfect steamed milk, my Rancilio do not so far.
If I put the steamerhead into the buttom of the milkcontainer there will not be any good steamed milk, I have to have the head just below the surface to make a good steamed milk. Could the preassure on the steamer be to low? And possible ways to solve the problem?
Is it only lack of practice or could there be something wrong?
  • 4 Answers
Make sure the milk (doesn't matter the fat content) is COLD. Then USE EXTRA MILK...(more than you need) that way it stays colder during the steaming, and it will froth instead of break. If it heats up too fast with too little milk... it will start to bubble and remain watery instead of producing froth. I use almost a full cup of cold vitamin D milk.... then I keep the steam head just below the surface..... Do not put the steam head at the bottom. This way some air is pulled into the steam and helps start the frothing process. I continue bringing the cup of milk lower and lower as the foam gets higher and higher, so the steam head continues to be just 1/4 inch below the surface. You will have super creamy foam (not bubbly foam). It takes a while to get perfect, but its worth it. Don't worry about expunging the condensed water at the start ... that really doesn't make a difference. Hope this helps!
Posted on Jul 29, 2010
    Novelist:
  • 137 Answers
Please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Posted on Mar 30, 2009
SOURCE:
When I run water through my Rancilio Silva it comes out milky. Why?
Rinse the machine with Baking Soda solution (2 to 4 quarts).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 25, 2016 | Rancilio Coffee Makers & Espresso Machines
Can I regulate the temp on our machine? our Rancilio machine seems to be to be running on too high a temperature. Meaning, we barely turn the steam wand on to steam milk (after the light goes off), an
Silvia has two bimetalic switches that control the boiler temperature. One for brew water and one for steam. They are not exact and they can go bad. They are cheap and easy to replace. Just Google for Rancilio parts.
A much better fix (and more expensive) is to switch to PID control. Google for Rancilio PID control. The conversion is $250+ but once you've gone PID, you'll never go back. The temperature is exact, fast, and totally under your control.
Jan 12, 2015 | Rancilio Silvia Espresso Machine
Hi I have a Ranchilio Silva machine all of a sudden the water smells burnt and taste of coffee is yuk, any thoghts
  • Make sure your using filtered water
  • After you steam, turn of the steaming switch and hit the water switch and let it go until a steady stream of water comes out then switch it off, this refills the boiler
  • Try to descale it or backflush it, with Jo Glo or Full Circle.
good luck!
Jul 11, 2011 | Rancilio Silvia Espresso Machine
We've had the Rancilio Audrey now for a year and still not have had a perfect cappucino. 1. Milk. We use 3.5 dairy milk, cold before going under spout. 2. What is the middle (steam) button used for? ...
  1. That is the right milk. Use a thermometer with the milk.
  2. The middle button is used for steam. It engages the high themostat for steam.
    1. Slightly open the steam valve
    2. Turn on the middle button
    3. Keep the end of the steam wand slightly above the milk surface (0.5 mm) so the steam incorporates air into the milk. (Takes practice)
    4. Open the steam valve as the boiler heats up. (Takes practice)
    5. When the milk get to 74 C (165 F) immerse the steam wand into the milk and heat to 82 C (185 F)
    6. Turn off the middle button and shut the valve.
  3. For 90 ml of coffee, use 14 gram of ground coffee. The coffee scoop that came with the machine holds 7 grams of ground coffee as it comes out of a grinder (not packed). Tamp the coffee after it is in the sieve.
Jan 01, 2011 | Rancilio Audrey
The steamer on our raniciolo silva does not work: the top light does not go out and no steam comes out
More than likley its your steam thremostat. Replace it and you should be good to go. Its on top of the boiler and the one that doesn't have the red dot on it.
Aug 28, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
5 year old Rancilio Silva with no heating of water
Hi
Do an ohms check on the element. With an ohms meter check the reading between the elements. The reading should be between 12 and 16 ohms for a 110v machine and 50 to 60 for a 220v machine. If you have no reading or a higher reading you have a bad element.
Replace the boiler
Jul 24, 2009 | Rancilio Silvia Espresso Machine
Super hot water out of the group head on my Rancilio Sylvia
My Rancilio Silva is not making the water or steam hot anymore. Is it fairly easy to replace the heating element?
Dec 29, 2008 | Rancilio Silvia Espresso Machine
Steam nozzle
For the coffee - make sure the machine has heated up for at least 10 minutes. I've found the grind is the most important in getting a good shot of espresso with a good crema.
It takes trying different grinds to find what works best. When we grind at the store we choose the second finest grind from the finest - we put it to Turkish and then turn it back one notch.
On the steaming side - it takes practice. Sometimes I get froth, sometimes - I usually let the wand go near the bottom of the steaming cup and heat the milk to 160 deg. f.
Apr 06, 2008 | Rancilio Silvia Espresso Machine
Steam problem
If the milk scalds, you're getting it hot enough. It sounds like you're not incorporating enough air into the milk when frothing.
Make sure that the holes in the tip of the steam wand are clear. Soak in water for 5-10 min. and wipe with a cloth (no abrasives) and clear the holes with a paper clip end. Blow the wand out nice and hard.
How is your steam pressure? It should be about 1.2 bar.
It could also be your technique. The wand should never be more than 3 cm into the milk. For cappuccino froth, keep the tip right at the surface of the milk, lowering the pitcher as the level rises. You should hear a "shushing" sound, no squealing.
Aug 28, 2007 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
469 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
