Windows boots then shuts off - Computers & Internet
    Sergeant:
  • 313 Answers
If it is a laptop, I would say it is the battery, or the power cord. I have had to replace many a defective power cord.
Or ...
How far into the booting process does it go?
or ...
Will it boot to the recovery CD? If it does, tell us, and we can help you "repair" windows instead of losing all your files by a complete re-install.
Posted on Jul 22, 2008
    Genius:
  • 2,785 Answers
Plz try to boot in safe mode if the problem persist then you have to repair or reinstall the os
HOW TO ENTER SAFE MODE
hold down F8 when it powers up. May need to remove battery and power cord. New windows 8 and probably windows 10 do not fully power down usually you have to hold shift key when shutting down windows from operating system. So it may not go into safe mode without it being shut down fully.
Nov 22, 2015 | Acer Computers & Internet
Laptop is turned on and screen displays message "selected boot image did not authenticate. Press enter to continue. when you press enter it shuts the laptop off.
I am assuming you are installing Windows 8 as this message is related to Secure boot on Windows 8.
Secure Boot needs a System with UEFI supported BIOS and Secure Boot Enabled in the bios. Secure boot requires drivers to be signed and certified to run with Windows 8. Some of your hardware may not be supported because of this, and thus Windows will not boot, and shut down to prevent damage. See this Microsoft link for more details:
Secure Boot Overview
Mar 04, 2015 | Compaq Computers & Internet
Computer won't boot up
You have to give more information about the behaviour..You computer shuts off..when exactly ? Has it passed bios check? Are windows loading or windows screen appears..?Can you open bios setup while booting?
However..shutting off..seems to me that the Power Unit may have failed
Nov 11, 2013 | Gateway Computers & Internet
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
Windows 7 is shutting down my graphics card (Nvidea) ...error 43...and freezing screen resolution at 600x480. Tried updating the driver, restoring the system to an earlier point, tried reboot at last known...
Press "F8" before Windows boot and you'll be presented with Advanced Boot Option. Select Safe Mode and hope it can booted successfully into this mode. Uninstall the related driver and reboot the system to normal mode.
Once it is booted, install the driver obtained from NVIDIA which is WHQL certified for Windows 7. Once installed, reboot your system and hope it works now.
Jul 14, 2010 | Microsoft Computers & Internet
Starts boot up but shuts off before finishing
Try using recovery disk. Or insert the Windows Instalation disk and then press "fix Windows Boot Up"
May 27, 2010 | Acer Aspire One PC Notebook
Boots up windows runs for 5 mins then system shuts
You may have a cooling problem (with older computers), if you hear your fan running excessively and then it shuts down on you. Otherwise it is more likely a hard drive issue.
Jan 25, 2010 | Toshiba Satellite P25-S5263 Notebook
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Copmaq shuts down on boot-up
This is because files that windows xp needs to function properly are corrupted or missing, so you would have to repair or re-install windows xp using the operating system cd.
please rate me. thank you.
May 29, 2008 | HP Compaq Presario v3000z Notebook
Computers & Internet Logo
David Payne
David Payne
