Question about NetGear WGR614 Router
Netgear router problems
I have had my Netgear WGR614 V.6 home router for 2 years now. Has worked flawlessly the whole time, except for the occasional power outage reset. Now, I cannot connect to internet while wireless suddenly. I have one laptop at home which still works while being wired through my Lan 1 port. I took my laptop to a WiFi hotspot and no problems. This leads me to a connection/software issue with the router.
I called my ISP first to check the modem. No issues there. Then I called Netgear support. They ran me through uploading latest firmware. After much time on the phone, I was told that I would receive a callback within 2 days with a possible solution because all options had been tried. It has now been a week.
I realized that the tech support never even had me reset the thing, so I followed the instructions on my router support page to no avail.
So, I am still stuck with a router that connects through the LAN, and the proper lights are on wired and wireless. It even shows that the network is connected on the PC, sometimes full, sometimes limited connectivity. I sure that I have messed up the process somewhere, but can't wrap my head around it. I have also shut off my windows firewall and disabled the router security as well.
  • jjwally Jul 22, 2008
    Already disconnected and reconnected a million times. I have tried starting a new network with new encryption keys to no avail. Also, same issues listed with no encryption as well.
  • jjwally Jul 23, 2008
    I was able to set up a test network and see it, but am not able to connect to internet. I get a limited or no coonectivity part of the time and after restarting computer, I get full connectivity, but still no internet. I have run a virus scan but nothing unusual. You suggest an IP conflict. What is that and how do I troubleshoot that? I know how to run ipconfig, but don't know what the info means.
  • 19,396 Answers
Disconnect wireless connection from laptop and connect it back, ensure that you are connected to your own wireless networ and thet the encryption key is correct.
Posted on Jul 22, 2008
  • Ginko
    Ginko Jul 22, 2008
    Then, if you know how to set up your network, set a new wireless and save settings, if you do not do save all the router will lose setting on startup.
    Does not matter if you set security at this point, put no encryption.
    Call the new wireless (set up network id ) to 'test123', with no encryption (unprotected).
    Check on your laptop now, if you cannot see the Test123, but you can see other wifi networks, then it is likely a faulty router (often broken antenna contact).
    If you do not see any wireless at all, either you live in a lonely place or your wireless network adapter in laptop is faulty, replace drivers or reinstall it.
    If you see test123, connect to this network, if internet does not work after connecting to new test network, then your connection had limited connectivity, probably an IP conflict or a virus on laptop, in this case you need to troubleshoot further.
  • Ginko
    Ginko Jul 23, 2008
    If yoau really wont to troubleshoot this you have to proceed the following way:
    1 - Identify cause for the problem - You need to understand if it is the router or the computer connected with wireless. Test using a different laptop, eventually borrow it from a friend, If the new laptop works, then it is not the mrouter.
    2A Problem is with router (no wireless device connects to router)-
    You did already a lot of job on the router. A router is not an expensive part , just replace it.
    2B Problem is located on your laptop (You can connect with different laptop)-
    • Try first removing your wireless adapter from installed hardware on device list. Disconnect adapter if external or tur it off if internal. Chose delete files if required. After this reinstall drivers , this will fix many TCP IP problems.
    • If you are using an external (PCMCIA/USB) wireless card just replace it.
    • Reinstall the system, some of the services concerning wireless network may be corrupted. Before reinstalling Window I boot windows from a special CD to verify if it is a system problem. Not having this tool all you can do is booting from 'Safe Mode with Networking and test it.
    • Check that TCP-IP has been set up properly in netwrk connection properties. Most network require dynamic tcp/ip check that is not set to static.
    • Re-assign mac address to wireless adapter, this can solve IP conflicts. There are several ways to reassign MAC address here is one, google out to find more.
    • Check for viruses , malaware etc. use Hijack this to get a system log, eventually post log here, I will answer within 24 hours.
    • Find someone like me in your area and call him, we fix hundreds of routers in same conditions every year, all we have got to do is spend some time in locating the problem to find out what part is to be fixed or replaced.
NetGear WGR614 Router network disappears
I would replace it, or, put it on a power strip with a switch and switch off when not in use, switch on when you come in. Take a look at these: http://www.tigerdirect.com/applications/category/category_slc.asp?Recs=10&Nav='c:373'&Sort=4
Feb 26, 2013 | NetGear WGR614 Router
Netgear wireless with mediacom internet-help!
Hi JC
Have a look here
http://kb.netgear.com/app/answers/detail/a_id/12873
This is a walkthrough showing you what to do.
Mar 16, 2010 | NetGear WGR614 Wireless Router
This router is not working
Try the reset button to put it back to factory default. If it's still not working, it's time for a new router.
Feb 26, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear DGN 2000 won't connect to internet by cable / wifi works
Might I suggest looking at the routers configuration. This can be done by typing in 192.168.1.1 into your web browser. Typically the default log in is: User Admin, Password is password. You want DHCP set on. Save all your settings. Then reset to factory default. There should be a reset button on the router. This will reset it to when it was new- any changes you made will be gone.
Oct 11, 2009 | NetGear DGN2000-100NAS Router
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Netgear RangeMax Wireless Router--trouble opeing ComCast email
Sadly the mimo router you show in the picture is similar to the one I had. I still have it, and it works somewhat. I had the same problems, and Netgear had no fix for me.
So I fixed it with dlink, I went and bought a dlink router and the problem vanished. Sorry to reply like this, but it was the only fix for me. The dlink router has worked flawlessly. I refrained from further Netgear purchases after this. The problem has not returned. :) Now please don't rush out and buy dlink, any other brand will work, like linksys, or belkin. Sometimes the problem is caused by the brand. This problem and many like it caused Netgear major problems they'll never recover from.
Word of the wise..Quality can never be fixed by quantity. Pay the extra $10 and get a decent router.
Feb 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
WGR614 Netgear Router consistantly dropping all connections
Probably an issue with the DCHP broadcast flag in Vista. See the following article - I would recommend doing this first, if you have not already done so:
http://support.microsoft.com/default.aspx/kb/928233
Dec 22, 2008 | NetGear WGR614 Router
Linksys BEFSR41 V.2
The only way to revive the router is by doing a reset. If it still won't work I hate to be the to tell you this but the router is busted. Consider yourself lucky that it worked flawlessly for eight years. =)
Oct 09, 2008 | Linksys (WRT54GC) Router
Router DG834G v2
I've got a similar issue except my router now cant find the ADSL line at all. Had it three years though. Maybe its time to get a new one. But it wont be a netgear.
Jun 18, 2008 | NetGear DG834G Router
Get booted off
Ok. i have the exact same problem, but i use linksys. I have has geeksquad and they dont know. I have only one option i havent tried. try to just hook up the modem to your router only. Buy a wireless adapter for your home computer. If it doesnt work, return it for a refund. I feel for you guys because i have been going through hell and it drives me crazy that even geeksquad doesnt know. (By the way dont buy that garbage when the people say you need a new router, because they just want more money.)
Mar 22, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear WGR614 Router Logo
132 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
