Question about EliteGroup P4M900T-M (V1.0) Motherboard
Bios problem The pc refuses to boot, nothing on the screen the monitor does'nt display even a blmack screen. all this is caused by some changes of the Bios settings. I have removed the battery and used the cmos clear jumper without any result.
It's okay I have found the cause of all this, the problem was in the RAM which has been made  out of order by some settings of the speed parameters in the bios. Anyway thank you ginko for your help. peace be upon you. salamo alaykom
Posted on Aug 04, 2008
  • EliteGroup Master
  • 19,396 Answers
Looks like the Motherboard is fried
Disconnect all devices from motherboard, try starting motherboard only with PSU, RAM, CPU and CPU fan , eventually Video adapter if you use PCI one.
If it does the same easiest thing to do is replacing motherboard.
The bios eprom can be re-programmed at a repair shop, but today, as motherboards are not too expensive, it is difficult to find a shop that does this job.
Better replacing the motherboard.
Posted on Jul 22, 2008
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
http://www.bootdisk.com/
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Helo, i,m in a greate trouble. i forgot my laptop acer extensa 4620 bios password. and now i could,nt install any operating system. cause i need to change the boot device from bios. i,ve tried a lot. but...
im sorry to hear that but unfortunately, if youre not the one who created the BIOS password, theres no way for you t acces it anymore, what you can do is to reseat the CMOS battey on the motherboard so that BIOS password will be reset.
Hope this will help...
Jan 19, 2011 | Acer Extensa 4620 Notebook
Netvista 6350 lost screen connection after BIOS password reset
If there a separate AGP Video Card in the system? If so, is there also a VGA connector on the motherboard? If you have both, try swapping the screen over to the other one. You may have reset the default video card back to the motherboard.
However, it looks as though you are using onboard video as you appear to be using 256Mb shared RAM for the video memory as your total should be 1536Mb.
In that case, you may need to do a rurther BIOS reset. You can find the complete instructions here
Nov 28, 2009 | IBM NetVista PC Desktop
When I Boot up it Dosent display the screen Any
What you've plug ?
if what you mean is a socket monitor to VGA port,
i think you have a problem with your monitor.
try to use another monitor if U have one.
boot up doesn't display ?
go into BIOS setup,look for "load BIOS SetUp Default or Load For Best Performance".
Choose it,Save and Exit.
Sep 25, 2009 | Dell Dimension 2350 PC Desktop
I have a p5n sli motherboard which refuses to boot
Go to page 2-30 section 2.4.5 in your manual.
If you are using the onboard graphics for your display set this to [PCI]. If you are using the PCI-E video card, set the bios to [PCI-E]. Save & exit the bios. You should have display after the system re-boots. If you still have no display & you are 100% sure your monitor functions than the video controller on the board is bad. This can not be repaired.
Mike
Jul 31, 2009 | ASUS P5N-E SLI BULK PACK of 10, Quad,775...
Green display on boot up Please help
Check to see that there are no machine BIOS settings that could affect the monitor. Normally, the bios controls display until the OS takes over. If your XP screen after bootup looks fine, I don't see how you have a problem with your monitor setup under Windows.
Jul 03, 2009 | Computers & Internet
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
The laptop appears to boot but no display even on ext monitor
Check the memory bank "Ram"... If you don't know how to change it, I recommend you go to a professional that will test it for you...
Mar 31, 2009 | Computers & Internet
Mag monitor doesn't display bios post
The BIOS is sending the display information to the monitor but, when you turn your PC on, the LCD will be sleeping and it will take 1~2 seconds to wake up when receiving the display signal. The monitor is working and even if the BIOS messages aren't displayed, you can still press the correct keystrokes to get to the SETUP screen or press PAUSE in the keyboard to see what's going on in the POST.
If your LCD has a bicolor LED indicating the status (Standby/On) keep looking at it, when the LCD gets the video data, the LED turns instantly from amber to Green or blue even if the screen is still black. This way you can have an idea when the LCD gets the initial video signal and to press the keys accordingly.
Your PC will also delay the video output from the secondary video card because it's detected after the onboard card.
May 03, 2008 | Computers & Internet
Monitor problems
wrong or incompatable display drivers.update or re install
Oct 31, 2007 | EliteGroup A530 Notebook
EliteGroup P4M900T-M (V1.0) Motherboard Logo
80 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
