Question about Frigidaire Refrigerators
Larder fridge is icing up inside have had a look at the back and noticed it is very hot
  • 833 Answers
There are a couple of reasons for ice-up. Let's check them:
  1. First, clean any coils in the back or underneath completely.
  2. Defrost the unit thoroughly. This could take a while and may lead to a quart/liter of water coming out. Usually this takes a day or so but can be sped up with a hair dryer or other heat source...electricity and water DON'T mix!
  3. Make sure all circulation vents in the box are unblocked.
  4. Start the unit. Watch the larger of the two pipes coming to the compressor...that big black thing under the fridge. It should frost up and then either dry out or stay wet after a half hour or so. If the frost stays on while the compressor is running, you are short on refrigerant gas...you'll need to get additional gas added.
Note: minimize the amount of uncovered liquids, the amount of time the door stays open and clean off dirt on door gaskets (be sure they fit properly by sliding a sheet of paper between the gasket and the frame of the fridge...it should move with some snubbing.
Posted on Jul 23, 2008
How can i stop my larder fridge from producing lots of ice?
If your fridge is built into the furniture, pull it out by releasing all the retaining screw, clean the condenser and the areas behind your fridge. Dust and fluffs reduce the efficiency of the fridge. Also turn the dial to three, if it is higher, older fridge do not need to be cranked to higher numbers. If no joy call an engineer, the level of refrigerant in your system may need topping up. Will cost you anything from sixty pounds for a qualified engineer to do this.
Aug 15, 2014 | Refrigerators
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
LG Larder Fridge model GR-252 SBD IS FREEZING ON INSIDE BACK PANEL A LUMP OF ICE FORMS. How can I stop it?
this is a defrost problem . either the A D C a pc board on the back side of the frig . this main board controls the temp[t and the defrost . and has failed . repl it and problem is over .. mm hope this has helped .. feed back pls ..
Jul 22, 2010 | Hotpoint RLA80 Refrigerator
The Larder fridge part of my Ariston
sounds like the defrost drain is froze up use hotwater and blowdryer
Jan 29, 2010 | Freezers
Water in bottom of fridge
Probably has ice frozen under freezer tray or drain tube may be blocked by ice diverting water through freezer to fridge vents.
Sep 11, 2009 | Refrigerators
Larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Dec 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint fridge
that is probably caused by heath at the back of the fridge, check if the coil at the back is getting too hot.
Check if defrost system fan at the back of the fridge is working.
Nov 02, 2008 | Refrigerators
Ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Oct 02, 2008 | Refrigerators
Refrigerators Logo
230 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
