Question about Yamaha RX-V490 Receiver
Yamaha RX V490 Turning itself Off
Hi i just bought a yamaha rx v490 amp and it keeps turning off after around 5 seconds even with no speakers or inputs plugged in. Can someone pls help as im pretty ********** about my new purchase. The guy who i bought it from tells me it worked fine before shipment to me. Thanks to anyone who helps me out.
  • 4,234 Answers
The amp is in protect mode which means that the output section has a problem. With nothing connected, there are defective parts inside the unit. This type of problem is not likely to have been caused by any shipping damage. I would guess that the output transistors are shorted.
Dan
Posted on Jul 22, 2008
Yamaha receiver keeps turning itself off
Have you tried the unit without speakers connected , just left on it's own for a while?
Oct 31, 2016 | Yamaha RX-V490 Receiver
Yamaha receiver keeps turning itself off model .RX-V490
Have you tried the unit without any speakers connected at all?
Can I use an Ipod Dock with a Yamaha RX V490 receiver?
No, but you could still access the audio directly from the iPod...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to an amp or receiver. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
http://www.retrevo.com/support/Yamaha-RX-V490-Receivers-manual/id/319ci975/t/2/
Dec 01, 2010 | Yamaha RX-V490 Receiver
How do I connect to my Yamaha RX-V490 some bose speakers. The ones that are only 2
Perhaps if you named the Bose system or go to Bose.com and find its manual.
Sep 05, 2009 | Yamaha RX-V490 Receiver
My RX-V490 Amp. has no audio from Centre speaker.
Is your center mode set to "Phantom" instead of "Normal" or "Wide"? That would split the mono Center channel program and mix it equally with the programs for both front speakers so your brain would believe it's in the center.
May 17, 2009 | Yamaha RX-V490 Receiver
Can you run 200watt 6ohm speakers on the RX-V490
Hi I have just read the specs on about your Yamaha system and you cant run 6 ohm speakers to your amp. You have to impedance match the speakers and the amp otherwise the speakers will "blow". So you need some 8 ohm speakers, the wattage of the speakers doesn't particularly matter as long as they are not too weak or too powerful becasue the amp will drive the speakers no matter what but if the speakers are of a low wattage then the amp could blow the speakers if it is turned up too loud. The specs of your amp are given in the link below.
Yamaha
Regards
Rob
Nov 13, 2008 | Yamaha RX-V490 Receiver
Yamaha RX-V490 comes on, goes off
More than likely its going into protect mode to keep from blowing your speakers. That pop noise is DC getting to your speakers before it shuts off i would recommend checking for DC voltage at the outputs first. If your not electronically inclined take it to a shop. Let us know :-)
Sep 15, 2007 | Yamaha RX-V490 Receiver
Circuit Diagram of Yamaha RX-V490 requied.
I have the schematics in PDF file, but how can I send it to you?
Apr 16, 2007 | Yamaha RX-V490 Receiver
Yamaha RX-V490 Receiver Logo
392 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
