Question about Belkin (F5D7230-4) Router (587009)
After forwarding ports, lose internet connection on other pcs on the lan
I followed the procedure and used the correct ports for Deer Hunter 2005, but after saving changes I lose my internet connection on the other PCs on my network.I set the PC with the game in the DMZ.
    Sergeant:
    Champion:
  • 327 Answers
Welcome to fixya
Restet the IPs of all other computers this might help
if you do not know how this this is how to do it
first goto msdos promt
then type in ipconfig hit enter
then type in ipconfig/release hit enter
then typs in ipconfig/renew hit enter (might take a few min )
after that type in inconfig again and see if there is a different ip #
close the window and try to get on internet if yes then there you go if not might have to reboot computer and then try the internet
hope this helps you out have a good day :)
Posted on Jul 22, 2008
I just switched to TimeWarnerCable/Internet. How do I connect two PC's to the Aris TM602G Modem? Then How do I connect my Laptop? Bob
You connect the Aris to a wireless router with say 4 LAN ports.
You connect the PCs with LAN cables to the LAN ports on the wireless router and install a wireless card in the laptop if it does not have one.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 18, 2010 | Arris Touchstone 300a (CM300) Modem
Tip
Using Zyxel P-600 from two PCs
to use Zyxel router/modem from two pcs for internet usage : it has two ports 1 is USB 2nd is Rj-45 connector LAN port
connect it with one pc via USB cable and connect 2nd via LAN port using Cross cable then its one DSL connection from two PCs.
i am using it and it working good.
on Apr 20, 2010 | Computers & Internet
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Access my lan from the WAN
I assume you want to log into your pc from another pc outside your lan. To do this you need to forward port 3389 to your pc.
  1. Make sure your pc (the one you want to connect to) has a static ip address. Also, it should have a password on the windows account you use.
  2. In the router, forward port 3389 (tcp) to the ip address of the pc.
  3. If you do this correctly, you can go to any pc outside your lan, and use remote desktop connection to connect. When you start the remote desktop connection, put in the wan ip address of your lan. If you did the port forwarding correctly, you will be asked for a user name and password. Put in the username and password for your user account on the lan pc and voila! - you are logged into your lan pc remotely.
Let me know if this works, or if you need some more help.
Aug 08, 2009 | Zhone 6211-I3-200 Router
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
2 Eth Cards one for Internet & one for LAN
First of all, I would really recommend you to buy a Cable/DSL router. It is quite cheap, usualy more secure, much easier to configure and troubleshoot. Also, it does not require to have one PC up and running all the time, hense saving energy. Do you know that a PC running 24/7 may cost between 60$ and 100$ in electricity annually? This is more than the cost of a basic router!
But, since your question is about sharing your Internet connection with a PC, here are some guidelines. I will assume here that you are using Windows XP.
On PC1:
1. Connect the modem to Eth0 in the PC. Do not connect anything in the USB port of the modem.
2. Make sure that the link lights are lit both side. If they are not, you may need a cross-over cable (this is usualy not the case)
3. Configure Eth0 to get IP address DNS automatically
4. Disable (uncheck) all protocols except TCP/IP on Eth0.
5. Run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps.
On PC2:
Simply run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps. Specify and you Internet connection is through a Home or LAN network.
That should do it.
Apr 25, 2008 | Computers & Internet
Calculate network topology cost
Answers as follows
  1. $100 ({n(n-1)}/2)
  2. $50 (n links)
  3. 3 (number of pcs/2)
  4. 1 (in any hub topologyonly one pair would commm. at a time)
  5. Bus ( $40 n-1 links)
With Regards,
TPV
Jan 12, 2008 | Compaq NETELLIGENT 3024 24-PORT 10BASE-T...
Belkin (F5D7230-4) Router (587009) Logo
73 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
