Question about Uniden Computers & Internet
Bearcat scanner UBC120XLT, will power-up for 5 seconds, flash battery light, and turn off. New Battery pack in scanner. Has same fault when plugged into mains.
  • 903 Answers
SOURCE: BT Problem Battery/Power Problem
In my opinion it is always very risky to buy some second hand unit because you can not be sure if every hardware component works properly. The best solution for you is to contact service partner and let them check the PDA. It is also possible that power supply electronic has some malfunction
Posted on Sep 08, 2005
  • 903 Answers
SOURCE: Exhaust my main battery
It is estimated that you will have a few days to recharge your battery if the battery is exhausted.
Posted on Sep 15, 2005
Darkzy
  • 11 Answers
SOURCE: o2 mini power problem
could be either one - is your battery connection loose or anything if not ask o2 about it
Posted on Nov 30, 2007
Vegggie Boy
  • 28 Answers
SOURCE: Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Posted on Jun 14, 2008
SOURCE: bearcat scanner 210xl program manual
Here Is A Users Manual For The Uniden Bearcat 210XL 18 Channel Programmable Scanner.
Just Follow This Link And Save or Print It Out In .pdf Format.........
I Myself Used My Dell Laserjet And Printed It As (2) two Sided Pages And Have A Nice Looking Manual. It Is A Complete Instruction Manual That Tells You How To Set It Up!
http://www.repeater-builder.com/uniden/pdf/uniden-bearcat-bc210xl-owners-man.pdf
Posted on Nov 24, 2008
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Lights will not light on ryobi battery charger/cannot charge fairly new battery
Bad contact on battery use multymeter to check if voltage is there if not open the battery pack and see if bad connection exists or try another battery
Dec 25, 2017 | Ryobi Multi-Volt Battery Charger
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I have uniden bearcat ubc120xlt scanner ican not pick any. Channels could it be because it's not digital
  • Hi, I can help.
  • I would not say the scanner is worthless as it has many uses. But this scanner is not digital capable and any digital signals will not be received on this scanner.
  • You can still do plenty of listening on it though.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Uniden BC60XLT-1 Handheld Scanner
Why when i switch my hp 6720s on does the battery light flash amber then goes white nd the laptop switches off? all in 5 seconds
It sounds as if the battery is too low to power the unit on.
Firstly insert the battery. When you plug the PSU into the machine does a charging light turn on? If not then check the fuse in the mains plug as it may have blown. If the fuse is OK then you may have a defective PSU, although the motherboard could also be defective. Try a new PSU to determine if which component is faulty.
Now remove the battery and insert the PSU. Will the machine turn on or do any power lights illuminate? If power lights illuminate and the machine will not turn on then I would suggest the motherboard is at fault. If the machine turns on briefly the turns off before displaying the splash screen then I would suggest the RAM, CPU or motherboard is at fault.
If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit n the motherboard is fried.
Hope this helps,
www.PuterCare.com
Jul 04, 2010 | HP Compaq 6720s Notebook
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
Uniden bearcat bc100xlt Can you use regular batteries with this radio ?
If you open the 7.2 volt battery pack you'll find 6 AA NiCad batteries. If you're even a little bit handy you can "rebuild" the pack with 6 new NiCad or NiMH batteries -- a save a big chunk of the $80 that suppliers want for a new pack.
Jan 06, 2010 | Uniden Radio Communications
NEED A BATTERY PACK FOR A BEARCAT UBC 220 XTL
The battery pack is available at Community Communications in NJ. Phone number is 973-831-5900.
Dec 30, 2008 | Uniden BC248CLT Base Scanner
A135-s2276 won't turn on
Hi, for what you say the fault generates the battery pack, you must remove the battery pack and work without it until you acquire the new one, the equipment operates on perfectly without battery packaging.
Dec 18, 2008 | Toshiba Satellite A135-S2276 Notebook
Hi-- This is actually a problem with the Canon LK-51B battery pack that goes with the iP90v portable printer. We've charged up the battery pack and all the lights have gone out, indicating full...
electronics should not be relied on to realy confirm u need to use a second battery pack to connect ur printer n see if the same thing will occure. i guess the battry inside d pack may be dead even though its a new one.
May 24, 2008 | Canon Office Equipment & Supplies
Computers & Internet Logo
80 people viewed this question
Top Uniden Computers & Internet Experts
castletech
castletech
Brett Duxbury
Brett Duxbury
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
