Question about Dishwashers
Bosch integrated model SGV55M03
I have a problem with a dishwasher - its a bosch integrated model SGV55M03 only 3yrs old (would be use once a week only)- the outlet is connected to the waste disposal.
The drain motor keeps running continuously - reason being the float valve in the base is up as there is water in the base (under the unit itself not inside the d/w). When this is emptied (pulling out integrated machine and turning on its side) it then works for two cycles but then fills in base again.
A suggestion to solve this was that the outlet pipe (as the water in the base seemed soapy - but this maybe due to soap residue in the base not the water itself) was not high enough - looped - and so water was running back in but I tried this and it did run for an extra cycle but back to same problem again.
I would open the machine but I don't have a spec and for some reason could not locate the screws to remove the base
All assistance needed
    President:
  • 1,462 Answers
You have a leak -usually from the circulating pump. take top off, take side panel off and you should be able to check where the leak is
Posted on Jul 22, 2008
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Have moved into new home with Bosch integrated slimline dishwasher. I just cannot seem to reach any actual manual on -line; so I could simply print it off. Pls help. Had PET done and they could not locate...
From what you are mentioning, it appears you are not able to identify the model number of your Bosch slimline dishwasher.
Usually the model number is located on the inside top corner of the dishwasher on a sticker along the left or right edge.
You need some reference before trying to locate a manual. Check this site.
Once you find the model number (atleast first 6-7 characters) you can download from the Bosch site.
Aug 05, 2011 | Dishwashers
One year old Bosch dishwasher stop wrking.will not
Start with the basics: Check the status of the breaker and the electrical connections under the toe kick panel. If the unitis getting power, You may want to call the dishwasher helpline to see if it is a recalled model. A free replacement of the control panel circuit board is available for many of these, but if the power switch is the culprit, you will need to buy a replacement button.
I have written a guide to help with drainage issues. The helpline number is near the top. It is here. Thanks!
Jul 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I cannot be sure of the make/model - there is no power
It sounds like you have a bad controller which is an expensive part if it is over five years old. However, there is a recall on some Bosch dishwashers which involves replacing the control. If you call Bosch at 1-800-944-2904 they can tell you if your model is involved in the recall.
Apr 17, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHU4322 Dishwasher leaks in the door
Detergent dispenser gasket or faulty air vent.
Feb 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
As the machine is only two weeks old I would go straight back to the seller and report the fault to them - and take a copy in writing. Don't be fobbed off with any instructions to get in touch with the makers - your contract is with the seller and it is up to them to fix it! And if you mention compensation for the inconvenience caused by this defective product, it might help speed things up.
Hope this helps! D.
Jul 13, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Sep 04, 2007 | Bosch SHU3306UC Built-in Dishwasher
Dishwashers Logo
229 people viewed this question
Top Dishwashers Experts
