Question about Frigidaire Dishwashers
Dishwasher Not Draining
I recently bought a house that had a Frigidaire Quiet Clean model# MDB122LBS0 dishwasher. I've never owned or used a dishwasher before, so this is new to me. I've tried running the dishwasher, with and without dishes in it. With dishes, dishes are still somewhat dirty, cloudy, and stinky and when the whole cycle is done there is water standing in the bottom. I mean enough that it's almost coming out the door. As suggested to me, I ran a couple bottles of dishwasher cleaner through it and although it's cleaner on the inside the water still isn't draining. I pulled the dishwasher out to make sure the hose wasn't kinked and as suggested online, I checked to make sure it's hooked up to the garbage disposal. I'd somehow like to be able to fix this myself as I'm a single mom on a very limited income and due to being disabled because of back problems, it would be so awesome to have a working dishwasher.
  • 487 Answers
This sounds like a pump problem.
But before you take a look at the pump check indeed the drain out.
Simple way is take the hose off the dishwasher and blow while it is atached to drain and see if you can blow through it. If you can the problem is not there.
Check the filters in the bottom of the machine and than check the pump HERE you can find the parts and drawing of your machine
Posted on Jul 23, 2008
    Scholar:
  • 93 Answers
Try this, loose the clip that hold your drain hose firmly from your dishwasher side, check carefully if no debris blocked the hose connector, water suppose to come out from that connector if it does, your drain hose was blocked with debris or mold and particles like coffee seeds etc.removed them connect the hose back run the dishwasher.
You can also visually observed your wash motor, if rusting or humming, that means you need to change the wash motor.
Prince P
  • 3 Answers
In many cases the connection were the dishwasher connects to the disposal or sink trap will become stopped up with a build-up from materials from the dishwasher. With the dishwasher turned off disconnect the drain hose from the washer and sink connection. run an object through the connection going to the trap or disposal ( after shutting off power to disposal and clean out build-up. Shouldn't take over 30 min.
Froggman
Dishwasher backed up
If it drains to a garbage disposal, it could be the disposal is clogged up and needs to be operated. It could be the drain plumbing in the house. It could be in the drain hose from the dishwasher to the house drain. It could be the dishwasher pump or grate in the bottom of the dishwasher.
Dishwasher not Draining
Feb 08, 2015 | Frigidaire Dishwashers
Bosch dishwasher makes noise while draining
If your model has a separate drain pump? You may have something caught in the pumps impellers.
Dec 04, 2013 | Bosch Dishwashers
Dishwasher leaking from pump housing.
If it is not leaking around a shaft seal, you can disassemble it again and use permatex or silicon sealer on the mating surfaces
May 03, 2013 | Frigidaire Professional Series 24 in....
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
I see the pressure tower for a Kenmore Ultra Wash Quiet Guard dishwasher laying in the bottom of the dishwasher. I've just rented the house and haven't used the dishwasher yet. Does this pie
No, the designers put it in there for a reason; it won't work as well without it, as it would with it in. Probably the mounting tabs are broken or sprung. A new tower isn't very expensive. You can probably get one from SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Mar 28, 2012 | Kenmore Dishwashers
My Frigidaire Ultra Quiet Plus dishwasher is not draining after final rinse. What can I do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 07, 2010 | Frigidaire Dishwashers
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Trying to determine its age
Only from the manufacturer you can find. If you can note the Model No Sr. No of the machine, it is possible. If it is a discontinued model, it may not be possible.
May 20, 2010 | Frigidaire 24 in. FDB635RF Built-in...
It is not cleaning well--could it be my water
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
48iabna
Nov 11, 2009 | Frigidaire 24 in. FDBB840DC Stainless...
Frigidare dishwasher
can you give me the exact model # on your dishwasher and i will check for you.
Sep 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
305 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
