I cannot find the way to force my RX-V3800 remote to accept code for my sat reciver. First of all there is not cab/sat button in sourece area. Secondly I've tried to put 0880 code in each remaining area and was reiceving NG code...
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
me too
I found solution.
After pressing 'Learn' for 3 seconds press left arrow button to change the display to something like L:Sat. After that it is possible to enter the code.
