Question about Acer Computers & Internet
Hi there, my laptop (Acer Travellmate 2430) won't boot up. i have set bios to start from CD Rom and when it does with the factory recovery disc in it loads ram disc image then tells me that 'file setupdd.sys. could not be loaded. The error code is 4' do you have any sujestions? Thanks for your time. Chris
    Sergeant:
  • 313 Answers
Remove and plug your ram back in. You should be able to run set up. Your Ram could either defected or need to be resett in its slot. To do this : Hi there, my laptop (Acer - e110d84.jpg On page 36 of the travelmate user manual: 1 Turn off the computer, unplug the AC adapter (if connected) and remove the battery pack. Then turn the computer over to access its base. 2 Remove the screws from the memory cover; then lift up and remove the memory cover. 3 (a) Insert the memory module diagonally into the slot, ben (b) gently press it down until it clicks into place. acfa349.jpg 4 Replace the memory cover and secure it with the screw. 5 Reinstall the battery pack, adn reconnect the AC adapter. 6 Turn on the computer. The computer automatically detects and reconfigures the total memory size. You can download the entire manual : http://hollyecho.com/download/travelmate_2430.pdf Let me know if this helps, if not we will go on from there.
Posted on Jul 22, 2008
Want to put laptop back to factory settings it's a acer aspire 5359
Hi Debra
This will describe how to reinstall the Operating system on your computer.
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me
Bud
Oct 31, 2012 | Computers & Internet
Brought acer travel mate back to factory using recovery discs now it wont reboot.I put discs back through with no result
Check the bios settings, in boot settings you must set CD unit as first boot device, then you start PC with recovery disk 1 inside.
Sep 05, 2008 | Acer Computers & Internet
Tried to do a factory reset now cannot get notebook to work.
Hi edgar murang...
Try this solution to your problem.
How to reinstall the Operating system on your computer
Sep 21, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have 2 problems. My Acer Aspire 560z keyboard types garbage for some reason, so I am using an external KB. Then, I want to restore the laptop to factory settings, but the cd's are lost. I don't...
Keyboard - Do you have the NumLock on?
From the ACER support site:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Aug 12, 2011 | Acer Aspire 5610 Notebook
Need to reset factory settings to wipe laptop clean but dont have a disc
hi
there is two ways to do it.
Laptop Recovery Instructions
If you cant boot into windows
1. Power on the machine
2. At the white ACER BIOS screen, hold the "Alt" key and press the "F10" key
simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click "Restore to Factory Default Settings"
4. Click "OK" to continue
5. From here, the eRecovery process will update all the data on the C: drive
and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit
If you can boot into windows
Click "START"
All Programs
Acer/ Packard Bell/ E-machine recovery
Select "Recovery management"
Click "Restore"
Click "Fully restore to factory default"
NB: This process takes about 15 to 20 min
Jun 15, 2011 | Acer Computers & Internet
How to reset my computer to factory defalts like it was when i got it new?
Use a factory restore/recovery disc if one is provided when your computer is purchase new. Insert disc into cd-rom and change boot priority or if in startup there is a boot option, use cd/dvd rom as first boot priority and follow instruction. If one disk is not provided, with some (branded such as sony, hp, etc) a recovery/restore partition is created within the harddrive, if this is valid, when booting up the computer, there should be a F-key prompting setup or etc.... if there is press that F key and follow instruction. If partion drive is not created for recovery/resotore, then you must create one disc... You can create this disc when in the operating system, go to your start task and in "all program" see if there is any recovery tools or aplication, which is usually your brand application exm.... acer computer has "acer recovery" and use such program to create a restore disc, once disc is created, turn of computer and set your boot prefernce to cd/dvd and then insert your disc and restart your computer, a black screen will be followed and prompt you that it is booting from cd/dvd rom and follow instruction. If one disc or program is not provide, consult your computer brand and have them send a copy of your factory restore disc for a small fee at your own cost.
Jan 22, 2011 | Computers & Internet
I want to restore my laptop to factory settings its an hp pavilion dv4000
  • Using the recovery partition
    • 1 Turn on your computer and insert your recovery disc. Press F10 during start-up to open the console. This opens up the HP recovery console.
    • 2 Click "Next" on the screen that appears.
    • 3 Choose whether you want a nondestructive recovery (one that keeps your files in place) or a destructive one (one that erases your disk and rebuilds your system to factory defaults). If most of your files aren't corrupted or are still usable, go with a nondestructive recovery. Otherwise, perform the destructive recovery.
    • 4 Follow the instructions on the prompts that appear to restore your HP Pavillion.
  • Using recovery discs
    • 1 Turn on your computer. Press F1 at the first logo screen to enter the BIOS menu.
    • 2 Move to the Boot Options section of the BIOS menu. Look for the Boot Priority menu.
    • 3 Set the Boot Priority option to booting the CD-ROM first.
    • 4 Insert the first recovery disc into the HP laptop. Then press "Enter" on your keyboard to save your settings and exit. The computer will then reboot into the recovery console.
    • 5 Follow the instructions on the prompts that appear, to restore your laptop.
  • Jan 01, 2011 | HP Pavilion dv4000 Notebook
    How do i restore my acer laptop to factory
    Select models have the ability to have the operating system reinstalled from a hidden drive built into the netbook. To start the Acer eRecovery:
    1. Tap the Alt and F10 keys togther during Power-On Self-Test (POST while the Acer logo is being displayed).
    2. When prompted with a boot screen, hit the Enter key.
    3. After the Acer eRecovery program has loaded follow the prompts to reinstall the operating system.
    If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from Acer Recovery Media. In order to recover the system using Acer Recovery Media an external optical disc drive is required.
    1. Press F2 to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
    2. Arrow over to "Boot".
    3. Ensure that the external optical drive is plugged into a USB port.
    4. Refer to on screen instructions to set the first device to "USB CDROM".
    5. Press the CD-ROM drive eject button and insert the System CD.
    6. Close the CD-ROM tray.
    7. Press "F10", then press "Enter" to save the changes and reboot the system.
    8. The netbook will boot from the Acer Recovery Media, follow the prompts to reinstall the operating system.
    Please rate!
    B_R
    Jan 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
    How do i reboot my cpu to factory settings, programs ect..?
    You can either use your recovery discs that came with the computer and re-boot the computer with the disc in the drive. The computer should ask you to"press any key to boot from cd" when re-booted. If it does not you will need to go into the BIOS and change the first boot device to the cd-rom drive. Or if your computer did not come with any recovery discs you can use the recovery program if it is built into the hard disc drive. You can usually activate this by pressing "alt" then "f10" when the computer first starts up. Sometimes the computer will tell you what to press to enter recovery mode when it first boots up.
    Nov 14, 2009 | Compaq Presario C700T Notebook
    Im trying to put my pc bak to factory settings but the disc will not auto run
    For that you need to SEt first boot device as your cd or dvd rom in bios.
    When you power up the computer press F1 oe F2 or "del" key to enter in bios .
    Then go to boot option then set first boot device as your cd or dvd rom then save settings and exit.
    Then resatrt if your recoveri disk in rom then your computer boot with it.
    Let me know if you need more assistanse.
    Thanks.
    Sep 26, 2009 | Acer Aspire™ T180 PC Desktop
    Computers & Internet Logo
    50 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
