JUmbo250 floppy tape drive installation
I wd like to know how to connect the drive. The drive has to be at the end of the floppy cable? And the red thread on the flat cable inwards on the same side as the red power thread? what about adaptors to the *other* type of
floppy connectors? Very difficult to see whether there are pins outside of the cable female receptor. What about jumpers? And how to install the s/w then in order to recognize the drive? I had an external model before,it broke.
On starting, I get the error message "floppy(s) fail {error}(40)".
Grateful for some answers.
Robert
  • 3 more comments
  • robbanx Jul 22, 2008
    Hi, thanks for your comments. Now I shd like to know where to buy an adapter, from
    34 pin male on the drive to 17 pin male, a kind of connector or extender, like a
    gender bender, only, it mustn't convert male to female. It is very tricky to put
    the 2 times 17 female connector on the cable onto the contact on the drive.
    w the drive outside, ok, but inside u can't see anything and easily one row of pins,
    or even one pin ends up outside of the connector. Yours,
    Bob
    So where to buy one of these adapters? I know they exist, because I had one in a
    by-gone computer. -rs
    Hi, once again. The problem is that the pins on the male 34 pin contact on the
    Jumbo are easily bent and have been already out of place a couple of times, thus
    prone to break off. I once had an adapter that converted the 34 pin contact to
    a so called 'card-edge'. Then you simply 'thread' the *other* type of connector -
    on my cable there are two of them, actually two of either - on the card edge and,
    there you go.
    While I manage to connect the Jumbo outside of the computer after some trials and
    errors, this is nearly impossible w the Jumbo inside the computer. Either one row
    of 17 pins is outside the 34 hole case or even only 1 pin and it won't work.
    Thus, if I had this converter, I could thread it on the 34 pins w the jumbo loose
    in the open air
    so to speak, and then, on site, there wd be no hassle to connect w the *other*
    connector type. Did I make myself clearer? Where I got this adapter from,
    I cannot remember. My newest computer has no floppy, so these things might
    be tough to find. Yours, -rs
    About the Jumbo250 floppy tape drive. There is only 1 way to connect the floppy connector because of the "hump" on the f/ receptacle.
    (red=nr1 towards the EDGE, AWAY from power-red)
    2nd:There is a "jumperless tape controller board" which interfaced an external unit. On the board there's a floppy like 34(well 33)pin connector.Can it be used to direct the Jumbo250?I wd need an extra cable,of course.
    Thanks, folks.
  • robbanx Jul 23, 2008
    Final comment: the drive works. There were no extra cables, I used the existing floppy cable with 4 "knuckles"(right?), 2 of each kind.
    1)the real 3.5" floppy has to sit on the end of the cable,w the red threads together.
    There is the famous "twist" in the floppy cable...
    2)on the other side of the twist sits the Jumbo drive, note: w the red thread AWAY from the read power thread - the hump on the floppy connector indicates this. ---
    Other problem: after all the fiddling and booting, the W95 start disk won't boot any more... I manage to boot Dos6.0, swedish version, but dos6 doesn't recognize my
    logical partitions, calling them "non-dos"...
    next step: install Win95 (I'd prefer win98 which was somewhat more stable)...
    I used dos6.0 swedish version, that may cause incompatibility.
    The main issue here seems, that "dos" under Win95 had the (inofficial)
    version number 7.x. *this* might be the problem that I created logical
    partitions with dos7 instead of dos6.
    However the 3.5"disk (=w95 boot) is foobar, I can't access it at all. How this happened - beats me.
    Yours, -rs
    beats me.
  • 13,433 Answers
Hello again, think ive seen you here before, didnt the jumbo come with the right cables?
Posted on Jul 22, 2008
  • 1 more comment
  • Ekse Jul 22, 2008
    i recommend you look for a cheap cable if missing from ebay
    www.ebay.com
  • Ekse Jul 23, 2008
    If I remember correctly w95 uses fat or fat16 partition format, 32 came with 98 or 2000
  • Ekse Jul 23, 2008
    try another bootdisk from
    http://www.bootdisk.com/
    the 98 bootdisk with fdisk should be able to create partitions that work with 95, but I would stay away from fat32.
  • 19,396 Answers
Is it internal or external?
  • Ginko
    Ginko Jul 22, 2008
    document.tlSearch.tx.value=unescape("")
    If you are connecting the Jumbo as an internal drive, then use the floppy flat ribbon IDE cable.
    The jumpers are to set slave/master/cable selct, in case there is more than one unit connected to same cable.
    Connect first the unit as standalone, so that you can test it without worrying about jumpers.
    If you want to connect more than one device ( for example your old floppy) to same cable use the jumper, the original floppy is usual set up as master, set up new unit as Slave.
  • Ginko
    Ginko Jul 22, 2008
    What do you need this adapter for? The motherboard has a standard 34 pin IDC connection (male) for floppy on it. Just get a floppy flat ribbon cable and plug one side on motherboard, the other on floppy.
    Just locate connector on motherboard.
    Here you can buy the floppy cable.
    I don't think such an adapter exists.
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
JUmbo250
Yes it needs repair, I suppose the tapes are fine them selfs so they should work fine in another one, you will have to service the tape drive, you can get another tape drive and the tapes should work.
Jul 09, 2008 | Colorado Memory Systems Colorado Jumbo250...
What cables do i need and how do you install a t3000 tape backup?
You will need the floppy cable the normally goes to a floppy drive.
You will of course need power and the cable is on your power supply.
You will need drivers that can be dolowded from HP.
I hope this information does help please do leave feedback and ratings for your free answer.
Aug 10, 2010 | HP Colorado T3000 Travan Tape Drive
I have a gateway GT5692 and I dont know where to install a floppy disk or if I can install one.
I found a similar gateway that says the motherboard supports a floppy drive but, it did not ship with it therefore, you will need the cable that goes from the floppy to the motherboard. Look for a smaller version of an EIDE hard disk drive plug on the motherboard you should see the initials FDD near the plug using a light and magnifying glass if it has it just plug the cable in and connect the floppy to the other end also you will have to find the small power wire that the floppy uses coming from the power supply....it may be easier to just get an external USB Floppy Disk Drive as they are rarely used anymore.
Jun 30, 2010 | Gateway GT5692 Desktop Computer
Computer does not detect a Alps Electric Co. Floppy drive
check the data cable and power cable,does the light in the floppy stay on if so you have the power cable backwards.is the drive connected ot the right end on the data cable. if the answer to these are yes then you have a bad drive.
May 23, 2009 | Alps DF354H (DF354H168) Internal Floppy...
JUmbo250
well you can contact them and ask about it, maybe the would have a simple solution to it, or possibly repairs, don't know about the price but surely over the 20usd.
you could also try contacting the seller of the product if they would ship it overseas, I've ordered a few things from over there shipped over just fine to Finland.
Floopy disk
Hi
Regarding configuring flopy drive for desktop please check these things
The wire on the ribbon cable with the red stripe is the pin 1 end and there should be a mark on the floppy drive as well marking the pin 1 end. Sometimes a little arrow or triangle point at pin1 sometimes stenciled with a number.
Regards
Balisonu79
Feb 14, 2008 | HP External floppy disk drive cable...
Mitsumi FA4o4M Combo Floppy Card and Data card reader/writer
black cable to be connected on a free usb outlet on the motherboard
Feb 02, 2008 | Mitsumi (FA404MBLACK) (fa404m/black)...
Cannot detect floppy drive
The cable for a floppy can be tricky. You should see a red line running down one side of the cable. If you look closely on your motherboard, you should a little "1" imprinted on the board near one of the corners where the cable plugs in. Make sure the red line is on the same side. Take the other end, and on the back of the floppy drive you should see another "1", do the same thing and make sure the red line is on the same side.
Turn on your PC and try that. Monitor your floppy drive, and the light should blink a couple times while it starts up, and go off. If it stays solid, you should double check the cable connections, or try another cable.
You can then check your BIOS and see that it is listed, typically on the front page, or under the drives section.
Hope this helps.
Jan 30, 2008 | Asrock P4I45GV R5 Motherboard
P4VMM2 - ???
disconnect drive 'A' floppy drive and see if it will boot up without it connected. It may be that the floppy is faulty if you know the ide cable is on the correct way round, as your pc may be set to halt on all errors
Apr 09, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
