How do you turn up the brightness on a hyosung laptop
  • 981 Answers
With a baemyung oxyacetylene ignitor.  Or if you create the proper product category for your model of hyosung, maybe someone who knows the BIOS hotkeys will let you know.  They might have done under-bezel adjustment buttons, too....
Posted on Jul 22, 2008
    Sergeant:
  • 313 Answers
Push the 'f'n' key while pushing the brightness up key at the same time. The brightness key is usually accross the top row of numbers F6 or F7.
2006 Hyosung GT 650 R starter spins but doesn't engage
Hi, Emma the starter clutch is a separate mechanical gear driven component that is activated by the starter motor, it engages the clutch pack gear or the flywheel gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one "ONE DIRECTION" only and once the engine starts allows the gear to free spin with engine rotation. If the starter gear free spins in "BOTH DIRECTIONS" then the drive gear has failed, it might be serviceable on some models but usually needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Starter spins but doesn turn the engine
Starting problems
HYOSUNG GT 650 Service Manual
HYOSUNG AQUILA 650 FI Service Manual
HYOSUNG GT650SR PARTS CATALOGUE Parts Catalog
HYOSUNG GT 650 Manual
Aug 12, 2017 | 2006 Hyosung GT 650 R
My hyosung hyper 125 scooter won't even try to turn over the engine - it was running when I got it but now won't turn - could this be the solenoid or the switch?
Hi, Janie and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
why wont my hyosung start
Scooter Troubleshooting Scooter won start All about Scooters
http://www.hyosung.hu/download/pdf/data/service-manual/HYOSUNG%20MS3%20125%20250%20service%20manual.pdf
http://www.hyosung.hu/download/pdf/data/alkatresz-katalogusok/Hyper125.pdf
http://www.hyosung.com.au/downloads/manuals/SF100.pdf
Mar 07, 2017 | Hyosung Motorcycles
2006 Hyosung GT 650 R water pump side plate
Hi, Samuel for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 Hyosung GT650R water pump side plate Google Search
hyosung gt650 parts
HYOSUNG GT650 PARTS CATALOGUE Parts Catalog
HYOSUNG GT650 Owner Manual
Apr 06, 2015 | 2006 Hyosung GT 650 R
2001 Hyosung Kaliber 50 fuel line routing
Hi, Michael for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Hyosung, despair not, for a mere zero $0 you can download another one.
2001 Hyosung Kaliber 50 fuel line routing Google Search
Vacuum and fuel line routing
Hyosung Sense SD 50 Service Manual
Hyosung Parts Scooter
HYOSUNG TE 50 Owner Manual
Dec 13, 2014 | Hyosung Motorcycles
2007 Hyosung Avitar GV 650 the headlight keeps getting bright then it dims
Hi, Oliver if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lightling coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
Why does my headlight go dim get bright
Headlights bright then dim ELD or
HYOSUNG Aquil GV650 Service Manual
HYOSUNG AQUILA GV650 PARTS CATALOGUE Manuals
HYOSUNG GV 650 EFI Owner Manual
Jun 13, 2017 | 2007 Hyosung Avitar GV650
Whats the wattage or amperage output from the alternator
have you considered HID conversion as this would dramatically increase brightness but only use 35w
Feb 27, 2013 | 2007 Hyosung GT250R
Timing marks on a hyosung gt650r
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Yamaha despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2011 Hyosung GT650R timing marks Google Search
Timing marks on hyosung gt650r 2011 Hyosung GT650R
http://www.hyosung.com.au/about-hyosung/owners-manual
http://danger.ho.com.ua/Manuals/Hyosung%20GT650%20Service%20Manual.pdf
Feb 20, 2013 | 2011 Hyosung GT650R
I replaced my NGK CR8E spark plugs with the new NGK CR8EIX Iridiums on my 2009 Hyosung GV650...and immediately after starting up the bike, I heard an electrical buzz in the front of the bike and shortly...
Hi, Skjc01 before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced your OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity.
2007 Hyosung GV650 Avitar turn signal buzzer intalled
2006 Hyosung LED Turnsignals Fix
HYOSUNG AQUILA GV650 CATALOGUE Manual
HYOSUNG GV650 User Manual
May 01, 2017 | 2011 Hyosung GV 650 SE
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
