You need to check in your power board if you have a Ripple Control Reciever .
If you do have one and a green light is flashing and it is turned off you need to call your power provider to come and reset it for you . This should be a free charge.
The heating elements in these units fail eventually, fora number of reasons. The way I have checked them is to (carefully) check the voltage acrooss the heating element. If you get 220 volts, but no hot water, the problem has been isolated to a faulty heating element, which is not difficult to replace, after you drain the tank. And never power up the unit without the tank being full. The heating element will burn out almost immediately. Good luck!
Electric water heater are designed with two elements for heating the water. The upper element is what is called the quick recovery element which is control by a thermostat. The thermostat has a reset button that will open in an over temperature situation. If the reset is NOT tripped it is possible that the upper element or thermostat has failed. Until the upper element is satisfied ( up to set temperature) the lower element does not get any power through the circuit.
