Question about Hoover Refrigerators
Fridge dose not get cold but freezer is - Hoover Refrigerators
    President:
  • 2,712 Answers
Check the air vent between the freezer and fridge. That could be blocked.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
    Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
    The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
    Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
    • The defrost timer
    • The defrost thermostat (also called the bi-metal switch)
    • The defrost heater
    If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
    Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
    Posted on Jul 22, 2008
    Hy i have a problem with my fridge freezer , the fridge compartment is acting like a freezer going up to -16
    There is normally an adjustment knob inside the fridge, in the back or top to allow you to adjust the coldness. Numbered 1-9.
    If you have already adjusted that it would help if I know the type (side by side, freezer on top or below) and the brand. Most side by sides blow some of the air from the freezer side into the fridge side with internal fans and vents. How is the freezer side coldness knob adjusted?
    I would set both knobs to 5 and go get yourself a outdoor thermometer to put in each side. It should be about 35 in the fridge and about zero in the freezer. Remember it will be warmer in the top and colder in the bottom of each.
    Was the thermostat you replaced in the freezer or fridge?
    Feb 02, 2015 | Refrigerators
    Fridge too cold!
    don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
    Dec 01, 2011 | Refrigerators
    Frigidare model # frs26znh freezer side works good refrigerator side dose not get cold
    Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
    Refrigeratornot Cooling or Fridge not Cooling
    How to Defrost Refrigerator DefrostTimer Problem
    WaterRunning in refrigerator from Freezer
    Refrigeratoror Freezer not Cooling or Getting Cold
    heatman101
    Jul 13, 2011 | Refrigerators
    Frigidare frs26znh freezer side works good refrigiator side dose not get cold
    heatman101
    Jul 13, 2011 | Microwave Ovens
    Hi, Have model E522B fridge, freezer cold but fridge even on lowest setting is only just getting cold. Can I fix it myself? Thanks for your help
    The only thing a home owner can do to fix this is to make sure ALL the coils under and behind you fridge are clean. If that dose not work I would very strongly suggest calling a repairmen before you attempt to fix.
    May 02, 2011 | Fisher and Paykel Active Smart E522B...
    My refrigderator made a loud noise continuosly for about 30mins and since then dose not get cold again, only the freezer compartment gets a bit cold but not cold enough to form ice.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Ice built up and stopped the fan...
    Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    heatman101
    Sep 11, 2010 | Whirlpool Refrigerators
    Frezzer gets cold fridge dose not compressor and fan are running fridge only cools to about 46
    Most modern combination units have two fans; one under the cabinet to move air over the coils and a second concealed behind the cabinets to distribute the cold air to both compartments. When you balance them to get the desired temperatures in each, you are adjusting the air flow from the cooling coils. Typically, the freezer has the coils and the fridge gets a little via ducts in the rear wall. If this fan fails, the freezer will suffer least and that seems to be what you are experiencing.
    When the compressor is running, check the inlets in the back of the refrigerator to see if you have noticeable air flow. If not, that fan has failed.
    Nov 29, 2009 | GE Refrigerators
    Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
    The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
    Aug 31, 2009 | Refrigerators
    Trubleshoot refrigerator staying cold enough
    First review the troubleshooting steps in the instruction manual. Check the freezer and frige temperature setting control knobs. Make sure the fan, coils, compressor etc. are clean. Check the door seals, especially at the bottom. If all that does not work, do some more online research (which is what I'm up to right now because I am faced with the same problem).
    Sep 02, 2008 | Admiral 26 cu. ft. Side-By-Side...
    Refrigerators Logo
    314 people viewed this question
    Top Hoover Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    tom wright
    tom wright
    Jim Goldsmith
    Jim Goldsmith
    Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
