Have dec tv cannot get picture or sound will not auto tune
I have lent my tv to my sister which my son used only for his play station,never used for normal tv,no aerial,since my sister has taken it it wont do anything no picture no sound and of course I cant find the manual,I would say that he's been fiddling around with it but hasn't affected the playstation so we never noticed anything wrong hope you can help thanks regards kerri
  • 2,071 Answers
You mean to say is "dead set' .This kind of trouble is in power supply section busted fuse or busted regulator transistor ,or maybe no depected parts only brittle,loose,crack or cold solder joint of the circuit board...
Posted on Jul 23, 2008
  • LORETO LACARON
    LORETO LACARON Jul 23, 2008
    Coldsolder issues - each
    component is soldered into small
    holes on the printed circuit board which in turn connects said
    component to the
    other components. Due to time, heat, use, some solder joints would be
    cracked
    or loose. It is possible that the cold solder is still minimally
    connected
    (hanging by a thread). When the TV turns on heat would be
    generated which would
    be sufficient to further loosen up the solder joint to the point it no
    longer
    provides electrical contact. Jarring the unit creates movement inside
    enough to
    re establish the contact, sometime good enough sometimes not enough.
    Again, since the unit still operates (sometimes) then it is highly
    probable that there are no defective components. As you have surmised, it is
    possibly a loose connection, solder joints are "connections"
    except that molten soldering lead is used to attach/connect the component to
    the board, "loose connection" in this sense is equal to "cold
    solder".
    Again on the assumption of no defective parts, then seeking a more
    experienced
    buddy for the soldering might be to your advantage. This is of course
    in
    addition to the possible electrical hazards when repairing.don't forget to rate ;this is the only way i get paid for my works thank you in advance..
    Good luck:
  • LORETO LACARON
    LORETO LACARON Jul 25, 2008
    don't worry i will rate you so can become like me,and can solve cash premium solution..see you soon there.....
    good luck and regards,
  • 25 Answers
Yeah, what VOTIT said.
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
Cant pick up any stations
Does this TV have Digital?
You might need a converter
Jul 25, 2009 | Televison & Video
No sound when playing a tape and wont tune in to the tv stations
No sound on playback is normally the scart lead not fully in either the vcr end or tv
Apr 27, 2009 | Panasonic Televison & Video
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Feb 24, 2009 | Toshiba 19A26 19" TV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
Oct 06, 2008 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
No SOund
cheak sound output settings and cable to pcm not dolby digital
Feb 02, 2008 | JVC DR-M10SEF DVD Recorder
Channel Reception
It sounds like a defective tuner or a IF module as well. It may also be a defective capacitor(s) or cold solder joints inside the tuner circuitry. I woud suggest to use a VCR or a TV convertor connected to an Audio/video input to change channels instead of fixing it.
Good Luck.
Jan 21, 2008 | Sony KV-27V42 27" TV
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
