Hi! Your model is equipped with an Automatic Water Level Float Device. It sounds like it is stuck in the UP position,. There fore the water is overfilling the bucket and not shutting off as it should.
The float is adjustable, so the you can set it for 1/2 full shut off or maximum full shut off. It may also be a case of the bucket is not properly installed in the holder. Turn the unit OFF and unplug it. Remove the bucket from the holder and reinstall it, making sure that the bucket fits "squarely" into the holder from top to bottom. Make sure that the bottom of the tank is not tilting downward in any way. Then, plug the unit back in and Turn the Master ON/OFF Switch to ON. If the buckei is properly installed, the unit should start automatically.
To further assist you, I have included a link to your Owner's Manual (in case you have misplace yours), that you can download & print for future reference. Pay particular attention to page # 6. As, it explains the operation and how to set the automatic float valve.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201187984.pdfI hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
