Zyxel ZyAIR G-570S - Wireless access point - 802.11b, 802.11g, 802.11 Super G
Problem for Zyxel ZyAIR G-570S - Wireless access point - 802.11b,...
Cant get onto Zyxel
By HZba on Jul 22, 2008
The problem is that, i know you have to go onto your Zyxel G-570s to change the setting for it to act as a signal booster.
But cant seem to get onto it, i have connected it with a cable and wireless.
I have typed 192.168.1.1 (as said in another problem topic) and 192.168.1.2 (as said in the manual), but nether addresses work, i tried to use Internet explorer 7 and Firefox, and nether of them pick up the IP.
Plz help me, i must be noobish but this boggles my mind
Comments:
Jul 24, 2008
- Agni: i changed my ip to both the above and that didn't work.
devidox: i did the power cycling didn't work as well as reset button (i tried this with my ip changed, and with my ip to normal).
I did the command prompt only ip assigned to the default gateway was the routers ip 192.168.0.1, if i type this in i only end up into the routers config. ps we are using a billion.
I also went onto the router and had a look of all the IPs that its picking up and non of them work.
My current setting for the WLAN is Gateway: 192.168.0.1
DNS: 192.168.0.1
any suggestions plz?
Jul 24, 2008
- ok i mannaged to get access to the Zyxel, i had to change the ip of my router (Billion) to the same range as the zyxel's ip, i then could change the zyxels ip to my next works range.
But after following the manual in setting it up as a repeater, i can access the internett through it, the laptops can connect but it doesnt seem that the Zyxel transmits between the router.
Can you please help me, in how to correctly set the zyxel up so that it would serve as just a signal booster to the rooter.
thank you
Best Solution
posted on Jul 24, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
DNS: 192.168.0.1
Solution #2
posted on Jun 20, 2009
Very Helpful)
cyberabbey
Rank: Apprentice
Rating: 100%, 2 votes
Change your conputer IP addres to 192.168.1.3
then open a web browser then open this address
192.168.1.2
then password default of theZyxel is 1234
then configure it....
mhon
mhon_09_11@yahoo.com
at friendster
woohlah
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jul 23, 2008
Somewhat Helpful)
devildox
Rank: Wiz
Rating: 81%, 16 votes
Is this a new machine straight out of the box ?
Try power cycling the machine by unplugging it and waiting about thirty seconds before you plug it back in. Now try using the ip addresses above. You might also look for a reset button and try that as well.
If you go into the command prompt, and then type ipconfig /all what ip address is assigned to the default gateway ? Try using that ip as well.
Write back if this doesn't help and we'll go from there.
Was this helpful?
Yes
No
Solution #4
Not Rated)
agni
Rank: Guide
Rating: 87%, 14 votes
you need to assign the ip address in You ethernet card TCP/IP settings
Was this helpful?
Yes
No
Popular Solutions for Zyxel ZyAIR G-570S - Wireless
Questions and Unsolved Problems for Zyxel ZyAIR G-570S - Wireless
Do you recommend Zyxel ZyAIR G-570S - Wireless access point - 802.11b, 802.11g, 802.11 Super G (ZY-G570S)?
Answer
Answer
I have a problem with my Colubris installation: As long as the accesspoints are on the same subnet,... (More)
Answer
I have an edimax ar7265wna wireless adsl/modem router that came bundled with an edimax wireless pci... (More)
Answer
the active LED on the PoE of when the cable connected to my outdoor AP is plugged on 2. my network... (More)
Answer
setting up the zyxel g-570s wireless access point
Answer
Hello, We have a building with offices in each level, We use Zyxel g-570s and a Skype Phone at each... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zyxel ZyAIR G-570S - Wireless...:
Top Wireless Access Point Experts
Rank: Guru Guru
Solutions: 1427
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Wireless Access Point Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
