Question about Brother MFC-410CN All-In-One InkJet Printer
Yellow is a greenish color
My yellow has gone green, I've repeated the ink cleaning process a heap of times and have played around with color preference etc.. nothing helps.. its still green, really noticeable and a pain in the **** when it comes to printing out photos.. they come out dark/dull and green looking.
And when I do the color quality test the black always has broken lines and cleaning doesnt help.
  • 1 more comment
  • emmyj Jul 24, 2008
    Hi, thanks for that.
    Yes I thought maybe I had put the yellow in the wrong place.. but nope all catridges are where they should be.
    In the printout the colors are washed out and dull looking nowhere near as vibrant as the test picture, the black has 3 lines running through it and the yellow still has a define green color to it.
  • emmyj Aug 14, 2008
    Hey thanks :) that did it!
  • Juram May 09, 2009
    I put new cartridges in the printer and the yellow prints green and the black does not print at all and this is after about 5-6 cleaning of the head through the menu in the 410cn. Can anybody help?.
    Thanks
    Novelist:
    Scholar:
  • 125 Answers
Try printing this test pattern. I got this from this other website. But as ridiculous as I may sound, did you put the yellow cartridge into the Cyan compartment? Because to produce green you need to combine yellow and cyan. This test pattern will tell you which colors are not working properly. Then we can trace which cartridge is the problem or not. Let me know the colors that come out.Yellow is a greenish color - 27dfd86.jpg
Posted on Jul 22, 2008
  • Miles Jul 25, 2008
    Hi Emmyj. Looks like your printhead is contaminated and has an air bubble in the black nozzles. What i would do is remove all the cartridges, clean the openings to make sure no contamination. Then remove the printhead and use a paper tower to clean the nozzles. Don't wipe it, just dab absorb the leftover inks. If you need to wipe, do so gently so as not to scratch the nozzles. Get DISTILLED WATER not mineral or tap water. ONLY DISTILLED Water, heat it up so it is warm to the touch. Not steaming hot just warm or below boiling point. Stand over a sink or newspaper laden table. Get a rubber tube and see if you can pump the water into the nozzles either from the top or bottom. Usually from the top is best,so that you can see if it clears up the clog and contamination at the nozzles end. Keep the water away from the any of the circuit board of the printhead. Keep them as dry as possible. I think this should correct your problem. I do this for a living so I have the tools to blow out the air bubbles as well as clean out the contamination. If you are unsure of working on it yourself then bring you printer to a Brother service center. Hope this helps.
Why does my Yellow ink print with a deep green tint on my Epson R220?
The symptoms point to some kind of contamination between the cyan and yellow. Most likely is that the yellow nozzles are picking up a small amount of cyan in the cleaning/resting pad when the printer is waiting to print... it's also possible the printhead has started failing and is allowing ink to mix somewhere before the nozzles...
The former is more likely however, especially if you are able to print a few pages of yellow where the greenish tint/lines fade out to become pure yellow.. but then re-appear after the printhead has rested.
Causes of this problem tend to be a backed up waste ink tube or failed pump.. Again it's more likely the former, especially if you've been resetting the waste ink counter and ignoring pad replacement or redirection of the waste ink.
Simplest solution is to locate the waste ink tube (accessible via the access hatch in the back of the printer) and then flush the tube through using a syringe of warm water (don't use excess pressure). Then fit an external waste tank so that the pad ink doesn't back up again (and solve the waste ink issue at the same time).
Obviously if the printhead or waste pump are failing then you have no other options beyond a new printhead, reconditioned model or new printer.
Hope that helps...
Martin
Dec 01, 2012 | Epson Stylus Photo R220 InkJet Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
I have a canon pixma IP6600D printer and just replaced blue, yellow and black ink and the colors are not coming out right
Go to "start menu", then "settings", then "printers and faxes". Right click o your printer, then click on "properties". A window with numerous tabs will open. Go to "maintenance". Click on "deep cleaning" or "cleaning". That will clean the print head that is in your printer, and the colors should come out right.
If the printer hasn't been working for a while, you will need to repeat the cleaning process several times in order to get a satisfying result.
Do bare in mind that this process uses a lot of your ink.
Apr 01, 2010 | Canon Pixma iP6600D InkJet Photo Printer
We also have a greenish tint. We put a new bulb in because the box that said bulb needed replacing came up. We reset the tv but its still green. we have tried to adjust colors, temperature adjustment and...
Your "light engine has possibly gone down on you, did you replace just the bulb it's self or the complete bulb assembly? If you pulled out light assembly and replace just the bulb then repalce light assembly, if you repalced the whole light socket assembly and still have greenish color the you have a "light engine problem". Seek repair tech.
Oct 01, 2009 | Sony KDS-55A2020 55" Television
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Problem with colored cartridge
Perhaps your cartride is low on ink, some printers will give you a status inside your printer settings on how much ink is in the cartridges.
Jan 27, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
1220c Ink blockage
Sometimes the nozzles get clogged. If several normal cleaning cycles do not clear all the nozzles, next try removing the cartridge and setting it, nozzle-side down, on a steaming-hot damp paper towel for a few minutes, then running a cleaning cycle. If this doesn't solve the problem, as a last-ditch effort the head can be soaked in a shallow dish of alcohol for a few minutes. This cleared up a clog for me that no other method would solve, but I have heard that if soaked too long in alcohol, the head may be damaged.
Nov 15, 2007 | HP DeskJet 1220c InkJet Printer
Brother MFC-410CN All-In-One InkJet Printer Logo
1,076 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
