I have dual boot 98SE/XP-Pro in same disk partition which got virus attack. In order to fix problem (long story), I had to remove and re-install the XP-Pro OS. Unfortunately I deleted the XP system from the win 98SE OS rather than uninstalling it and now on boot up, the boot list only has two lines the same for XP-Pro and i can't boot the 98SE. If I try booting the second of the two systems showing I get the message "file missing ICG32.dll from Windows root/system" Is there any way to restore the bootup menu correctly so I can get my 98SE system back (all 98SE files are OK and still accesible from XP system). Rgds, Paul (pstret@aol.com)
  • 981 Answers
Why would you torture yourself with that old thing?  Yeah, you can create more boot script lines...they should designate the proper root for the second volume and that ought to fix any missing file issues if indeed ICG32.dll and company are where they started....
Posted on Jul 22, 2008
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
I had vista and was installing windows 7 and got to the network part of the install and the system went to resart and it went to a black screen with a fashing curser and now i can not access anything on my...
guess u were trying to install Win7 over Vista...it does not work that way....Win7 need to be a clean install...that is...it must be installed in a new partition after doing a full low level format....so you will have dual boot at start up...and u chose what u want vista or Win7 to work with for that specific session....
Dual boot helps in many ways...
1 - it helps file management better
2 - it helps to boot from one OS in case the other gives trouble
3 - virus attack are removed from either OS
etc etc
the best way to getback you system is to
1 download KILLDISK (DOS) utility program, get the DOS version
2 copy it on to a CD
3 get hold of a Win98 CD (bootable)
4 boot from Win98 cd, dont chose to install Win98,
5 press ESC and let Win98 quit installing, it will lead to a drive letter of you CDROM (say D or E as the case may be)
6 insert the CD that has the KILLDISK DOS utility
7 Run the program by typing KILLDISK at the CD drive letter prompt.
8 Read all the options available there...and kill the drive in which you had VistaOS/Win7 (C)...this will make all you C: drive sectors to "0"
i.e. it will wipe your C: drive clean and u can start with a clean slate....
if u r not concerned with the data in you disk...wipe all drives and disks in the PC....a 20GB disk will take aprox 1 hr to finish
for all this u must have the BIOS enabled to boot from CDROM drive...
once killdisk has finished doing the wiping process....
insert the Vista or Xp cd and install either...in the partition option make 3 or more partitions....C, D, E of at least 30 GB min for each...as Win7 will take aprox 18 GB....
in C: drive install Vista or XP as the case may be.....
once done....let the system boot and let it load Vista or XP
once in Desktop you can insert the Win7 cd and install it on the D or E: drive....the CDROM drive letter will change accordingly....when you make the partition....so be carefull to
let me know....
reg
Jul 17, 2010 | Computers & Internet
How can i format my laptop?
u can format in progress install new windows
Jan 14, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Trying too dual boot xp pro on toshiba tecra m5. conflict image of original xp pro, in slim select bay hdd. Need help with settings so as the same op system can be used on both drives.Any help would be...
in order to dual boot something.... you need to partition the hard disk... if there's only 1... you need a program that will create another partition from drive C...
for example the size of your Hard disk(drive C) is 160gb
you need a program that will split 160gb into 2 it should come out and you will have now two drives (C & D) with a size of 80gb each...(It depends on how large you want the other drives to have)...
the program is called Partition Magic 8.0 if you want that program.. i can send it to you... just contact me in my yahoo messenger... derick_10_02@yahoo.com
now it's time to install the Windows XP in each drive then you'll have a dual boot... or you can install Windows Vista on the other drive... so therefore you'll have Windows Xp and Windows Vista in one PC...
hope it will help you... tnx
Jun 07, 2009 | Computers & Internet
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Mar 16, 2009 | Microsoft Windows Vista Ultimate Edition
AVG 7 detecdted Virus Hurri on partition table. How do I remove ?
You will need to fix the master boot record with the Windows XP Recovery Console. To do this, you will need a Windows XP install CD.
Here are the steps to use the recovery console:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
  4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
In this instance, the correct commands are:
c:\fixmbr
c:\fixboot
The type exit after finishing then remove the Original OS CD.
The machine will reboot properly.
This will fix your boot sector
And All should be well
Dec 28, 2008 | Microsoft Windows 98 for PC
On my pc running win xp pack2 i want to install win 2000 pro. how can i do it? please suggest me.
You can either run a dual-boot system where you can boot into XP and Pro when you start your computer, or reformat and install 2k.
If you want to dual-boot you would need a blank partition on which to install it. Unfortunately if you do not already have more than one partition on your current drive, it would be difficult to split a single partition drive into adding another partition unless you are familiar with the tools required to perform such an operation.
However, if you only need to install 2k without having access to XP, all you need to do is insert the Win 2k disk and follow the installation wizard. When it comes to selecting where to install, it should show a partition containing winXP, which you can then install 2K to. Remember, all files on your XP install, including the operating system itself, will be removed. You would lose everything on that partition. If it is a single partition drive, anything on the drive is removed. You should back up any files you want to save by either transfering them to a different drive if you have one, or burning them to CDs/DVDs.
Select the partition you want to install to (if it's a single partition disk, there will only be one listed. If there are more partitions, you can select a different partition to install to which would allow you to keep XP), and I would recommend selecting reformatting the partition to NTFS.
Once it is done reformatting and copying files, it will ask to restart. Restart the computer, but do not press any keys upon startup when it pauses to ask to boot from CD. Wait until the 2K graphical installer loads from the disk, and then you can follow the setup wizard for 2K.
If you have any questions or problems, please add a new post stating them, and I will try to answer.
Dec 14, 2008 | Microsoft Windows Vista Ultimate Edition
Cant install xp on my maxtor SATA 6V160E0 UDMA6
*If you have access to another computer with a cd burner*
One way is to download the universal boot cd, boot a linux rescue disk image from it and use fdisk to remove all partitions.
This way the disk will be seen by windows setup again.
This is a silly bug in windows setup i've discovered a long time ago. When it does not understand the partitions on a disc it just hangs during the setup screen.
Download the iso image from http://www.ultimatebootcd.com/download.html then burn the iso image to a blank cd. Put it in your dead machine's cd drive and boot from it. Then choose one of the linux boot options.
When linux is up and running type fdisk ENTER
Then press p and a list of partitions comes up
Press d (delete) and then the number you see after /dev/hda etc.
Do this for every partition you see listed or just for
the first if there is data on the second/third/etc..
Press w (write) q (quit) and reboot with the windows cd in place.
p.s. This does irreversably remove
partitions and data on the disk!
Jan 11, 2008 | Maxtor Hard Drive
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
