Question about HP Officejet 7310 All-In-One Printer
Hp 7310 all in one
Should be printing colour photos but they come out brown !
cartridges have been cleaned
test sheet shows colour
cartidges are 75% full
  • Miles May 11, 2010
    I can'r trace the problem. Do you think you can print this out and see which color is the problem?
  • HP Master
  • 19,396 Answers
First check that printer is not set to print B&W. Open an application to print a page, for example Word. Chose print command from the file menu on top bar , the print window will open.
In the print window press the 'properties' button, and check tha printer is set for color printing.t
Once you are sure printer settings are not in B&W, read the following.
Even if it shows color at 75, the printer color level may had not been reset since the cartridge had been replaced, in this case the cartridge may be empty.
If the cartridge is not empty it still can be faulty (eg. ink insid is dry).
In either case replace color cartridge with new original one.
If after you replace the cartridge it still does not print colors, then color head is faulty, at this point consider having the printer repaired by a technician.
Posted on Jul 22, 2008
Colors are off. Browns print green or purple. I
BROWN is made by mixing two of the three "primary" colours.
So, if the printer is out of RED ink, you'll get the "other" primary colour.
Print a "test" page, and verify that part of that page is RED.
Run a printer "cleaning" cycle, and consider replacing the RED cartridge.
Jan 08, 2010 | Canon i860 InkJet Photo Printer
Printer keeps showing Office Jet 8500 Wireless
The printer wants to align the print cartridge, if you print out the alignment sheet, and then following instruction, place on scanner and scan it in etc, and it fails to callibrate, I have found it is because some of the information on the calibration page is not being printed correctly so therefore machine cant calibrate the print heads from it, this is normally due to poor quality cartridges or failing/empty print cartridge or cartridges, these use two I think, and I bet one of the colours from the colour isn't printing properly, replace colour cart if blacks look good. Below is a link to HP so you can see what a alignment page needs to look like to pass calibration, compare yours and you may find a colour is dodgy on it.
see HP's support information
Nov 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
My hp 6110 doesn't print colour?
When you refill an HP cartridge there is a chip on some that tells the printer how many pages have been printed. This doesn't get reset when it gets refilled in a majority of the refill places. So you will have to ignore the low ink warning on those cartridges or get them done somewhere else like a Cartridge World. If in fact the ink tank is chipped, then they generally can't be refilled without resetting the chip.
Jun 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Colour problem
Its related to some problem in your cartidge get it replaced if it is in warranty peroid and always use hp original cartidge
Sep 07, 2008 | HP DeskJet 1280 InkJet Printer
The big black cartridge is full yet not printing properly
The same problem here... Strange enough, it begun suddenly this september 1st.
Sep 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
7310 Cartidge Change Issue
You can download the drivers and utility software for the Officejet 7310 from HP's site here or you can run a cleaning cycle from the front panel - select setup and cycle through the choices.
It sounds like you have a defective cartridge, most common with remanufactured cartridges. If it is an HP original you can check the two year warranty as shown here. If the HP oriinal cartrdige is defective and still in its warranty period you can return it to your dealer or contact HP for a replacement. If the cartrdige is a store brand or some other remanufactured cartridge contact your delaer for a replacement.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Photo printing
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
This report provides useful information about your print cartridges, including status information. If the self-test report shows a problem, clean the print cartridges.
Feb 10, 2008 | HP Photosmart C3180 All-In-One InkJet...
C4180 Professional Photo Pack
Yes, plastic cartidge holder is provided to you to store HP 337 (black inkjet print cartridge) as you remove it to install a new HP 338 ( Photo Cartidge).
Remember, below combination of Cartidges for used for specific purposes:
Black and color cartidge  for general Printing of Documents.
Black, Color, Photo Cartidge to Print Photos.
Color cartidge , photo Cartidge and gray cartidge is specially used when you to print copies of photos  with great quality.
I hope that this should resolve the issue for you.
You can mail me at thumuvikram@rediffmail.com for further assistance, I'll be glad to help you.
Bye
Oct 16, 2007 | HP PhotoSmart C4180 All-in-One Color...
208 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
