I need to change the drive belt on a Tricity Bendix 1200 washing machine. I have got the top of and can see the hole at the bottom of the machine but can't reach where the belt fits.
    President:
  • 1,462 Answers
The belt goes round the motor spindle at the bottom. tape belt to large pulley. tilt machine backwards and put belt over motor shaft and tape into position. start belt onto main pulley and turn it so belt eases on. it is a tight fit
Posted on Jul 22, 2008
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
How to take back off tricity bendix aw 1000 w
Tip the machine on it's side and fit it from underneath. It's a bit fiddley.
Dec 13, 2012 | Tricity Bendix AW1000W Front Load Washer
Trying to organise changing brushes in Tricity Bendix AW 1400. I'm in Scotland, daughter and machine in England! Does top or back come off machine to allow access and is motor fairly accessible for...
Washing machine motors are usually induction motors and do not have brushes? Anyway, the back comes off and that normally gives access to the screws that hold the top on, but the motor is normally located at the bottom of the machine.
Feb 14, 2011 | Tricity Bendix AW1400W Front Load Washer
My machine will not spin
You need a Service guy to open the back of your unit to see what is wrong. If Belt driven.. Replace the belt.. If Drirect drive.. Change the motor
Jul 21, 2010 | Tricity Bendix AW850W Front Load Washer
I need a new belt for my Bendix washing machine model L43RX.It was made in Italy but I am unable to find a replacement belt here in Australia
Hiya,
i have a link to a site here in the U.K. who supply parts for these machines & after checking with there delivery section at the bottom of there pages they do deliver to other countrys too.. Here is the link
http://www.espares.co.uk/parts/washing-machines/tricity-bendix/aw1000w/p/1085/1261/0/407838
this will take you straight to the page with the belts however you can look at other parts by using the navigation panel on the left when you get to there site.
Hope this helps
Apr 21, 2010 | Tricity Bendix AW1000W Front Load Washer
How to replace belt on tricity bendix aw440 washer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Oct 12, 2009 | Tricity Bendix Washing Machines
THE FABRIC SOFTNER DRAWER IS ALWAYS FULL OF WATER ON OUR TRICITY BENDIX 1000 WASHING MACHINE
This is usually because the fabric softner draw is prone to colgging due to a build up of gunk in the holes that drain the softner into the machine at the appropriate time. Remove the drawert (There is usually a thumb press release at the back of the drawer you will see if you pull it out as far as you can.
After removal, wash the drawer all over (paying particular attention to the bottom of the drawer). If you have a garden hose, take the drawer outside after you have cleaned it and turn the hose on, full belt, and blast out all the waterways in the drawer to make sure they are clear. Refit the drawer and this should sort out the problem
Oct 09, 2009 | Tricity Bendix Washing Machines
Tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Jan 22, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
