Storing Colour & Sound Settings
Hi, for some reason my TV won't store any of its colour and audio settings. I have tried re-tuning and following firts time installation porceddures a few times to no avail. There is a strong signal and I receive all the channels I am suppose to.
  • 558 Answers
This is a section for computer monitors not flat panel tv's however as they are similar you should take this back to the store for an exchange, if it is older(you didn't tell me how old is it), then I think that a new main board will be needed as the info is stored in the main micro chip and that is not repairable.
Posted on Jul 22, 2008
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
Will not store settings unless kept in standby. Contrast/Brightness/Colour/Volume
1. The on/off switch is not easily accessible because the remote control is used to turn the TV on and off.
2. If the remote is used, the TV is always in standby mode
3. When the power is turned off and then back on those settings go back to their preset values or the last preset settings.
4, You should be able to enter the preset settings with the original remote control,
Sep 17, 2017 | Watches
I have purchased the apple component tv cable for my ipod 5th generation but when playing back videos I have only sound - no picture. I have set the Ipod to tv out, PAL (Aust) & connected all the...
Hi, this seems to be a physical failure with your connections and not your TV input configuration (as you're able to listen to your audio). First, try to see if there's an obstruction on your iPod dock (maybe some dirt or dust) and on your AV cable. As the video travels through different pins than the USB or power, you may've not noticed the failure until now. Sony Bravia TVs are all built in the same factory, so they can easily change from NTSC and PAL, try going to your settings and change the TV out to NTSC. If everything else fails, take it to your Apple Store, they'll be more than happy to test it for you and if it's broken, replace it for a working one.
--Dennis
Feb 27, 2011 | Apple COMPONENT AV CABLE (MB128LL/A)
Sony trinitron only in blacka nd white. how do I return it to colour?
pls check your tv colour system it is not maching with your country col-sys [PAL /NTSC/SCHAM] so pls open menu and set col-sys select any one or set col-sys is AUTO see the colour pictur.
* NO colour [B&W} pictur
[1] cabel singnel is wek.Pls. check cabel canaction re set pin or cabel canaction.
[2] pls tune ch. set Auto serch or fine tune to set ch.
if not colour pictur then problum is inside of your colour tv set.
Oct 05, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No colour, contrast or volume memory. Channel memory OK, have fitted new battery.
Sounds like the eprom! I don,t have that manual in front of me but if it has a 8 pin eprom, try this, remove it and see if your settings are available and operational,( the ones in question) if they are then it is defective.
Apr 28, 2009 | Televison & Video
Storing
I have am model d:2932 and all of a sudden my sound is gone. Can you help?
Thanks
Dec 19, 2008 | Televison & Video
No sound on TV
If you do not get result you can purchase one video rf converter. Rf converter contains one video input in yellow colour and two audio in red and white colour and one cable connector as outout. Connect dvd output to this converter and tune the program in which place you receive dvd signal.
Sep 16, 2007 | Durabrand DWT1905 TV
Logitech Quickcam for Notebooks Deluxe - Web camera - colour - audio - USB
check the Audio tuning wizard of the program used with the web cam. make sure the right speakers and microphone are selected. I have heard of a bug in MSN Messenger 7.5 that doesn't allow proper setup of sound. If that's your current setup, you can simply use the Windows Messenger Audio Tuning Wizard to setup your sound properties. Either go through the start menu or go start->run->'msmsgs' after completing the audio tuning wizard, close Windows Messenger. The settings should be adopted into MSN Messenger.
Apr 09, 2007 | LG LPC-UM10 Webcam
Where is ny color
HI SIR PLEASE TRY TO CHECK THE COLOUR SYSTEM SETTING SELECT FOR AUTOMATIC OR THE PLACE COLOUR SYSTEM YOU LIVE IN FOR EXAMPLE (NTSC ) FOR USA
Jan 22, 2007 | Panasonic CT-2788YD 27" TV
Computers & Internet Logo
377 people viewed this question
David Payne
David Payne
