Question about Panasonic Televison & Video
Why do I always have the message:" A new DVB service has been found" when I switch my television on, and yet there are no new updates?
  • 45 Answers
Its not your TV its your free view box telling you its found more channels. DVB means 'digital video broadcast.' go into menu and select search or update channel list
Posted on Jul 23, 2008
Why is dvb mode blank and no dvb setup options?
Your set need a through check-up. Contact any service technician. A firmware update might be necessary.
Electro help
Jul 03, 2014 | Panasonic TX32LXD60 32 in. LCD TV
Many errors after installing a new HDD on samsung R480 laptop
HI , there ,
Did you back up your data ? if so just recconect your old hard drive if you didnt format it and run windows go to my computer right click and click properties scroll down the the bottom and you should be able to see your product key jot that down and reconnect your new hard drive install windows and enter the product key.
as for the windows updates look up the error messages , you might have to copy the folder and delete the old oneas sometimes the donwload folderr gets corrupt.
Hope this helps .
Dec 29, 2012 | Samsung R480 Notebook
Windows update stops working, check for updates failed
I've found that re-registering the dlls has solved quite a lot of windows update issues. have you tried this?
see method 5 here:
http://support.microsoft.com/kb/326253
Dec 22, 2012 | Toshiba Satellite X205 Notebook
Have had a DMR-EX75EB for a couple of years - great bit of kit but for some reason, the digital channels have all dropped out and i cant seem to get them back. I know the aerial feed is good because we...
It is possible that the built in DVB tuner of your DVD recorder has failed, since your TV still has its DVB receiver working fine. I suppose if you have tried to reset the recorder numerous times, and it still has not found any DVB channels, then yes, the DVB tuner has died - probably not economical to replace that as a separate component, since it is hard-soldered to the motherboard, making the overall replacement cost-prohibitive.
But if you want to do so, you can submit your recorder to any authorised DVD service centre for a quote, as well as a detailed description of the problem(s) (assuming the tuner is found to be the culprit); this will help you to make an informed decision as to whether to go ahead with the repair or not. Up to you.
Presuming your unit works otherwise, you should not need a new one (but an external set top box connected via the recorder's inputs may be required if you need to record channels) - but get a couple of quotes from service centres FIRST before doing anything else ((you can always say no to the quotes if they are too high).
Jun 08, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have a Panasonic DVD recorder with hard drive (DMR-EX769). EVERY time I switch it on the following message pops up on screen : "A new DVB channel has been found. Start DVB Auto-Setup? Selective...
I believe there is an option to stop that. It's just finding out on what menu it is on. Some Panasonic machines have it on the FUNCTION MENU then press SETUP then press DIGITAL TV TUNING. It's often listed as NEW CHANNEL MESSAGE.
Selecting that will switch it off or at least the options for it.
It's probably caused by weak stations that get detected then drop out again.
Jun 16, 2017 | Panasonic Televison & Video
Every time the machine is switshed on it indicates that a new DVB service has been found. This suggests it is not storing this info when it does receive it - any suggestions?
Unles you add the new channel(s) each time, it will flash the message. Go into the tuning menu and either add new channels or retune completly.
Mar 21, 2010 | Televison & Video
Will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
Jul 27, 2009 | Panasonic TX-26LXD1 26 in. LCD Television
I have a HP DeskjetF380 All In One Printer, scanner,copier which has been working OK & still does, but am receiveing continual message on my computer which interferes with my computing etc & is an...
Try going into control panel, add and remove programs and finding the HP update program. Uninstall this and you should nto get any more update messages
Fred
Jul 17, 2008 | HP Office Equipment & Supplies
System error found Divio Fusion hdtv Software dvb-t version 3.68
system error found Divio Fusion hdtv Software dvb-t version 3.68
Solution:- Re set drivers off the Divio Web Site,the installation disk that came with the product was out of date being an earlier version.
Two attempts were made to install new up dated drivers,incorrect product description was selected from off the list at first before correct description in the 3.68 version was selected
globalpage
Jul 17, 2008 | Televison & Video
Televison & Video Logo
470 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
