Question about Acer Aspire 5600 Series 5630-6951 Laptop
Laptop Monitor loose
Its Acer 5610z any tip my Laptop monitor falls n dont hold its loose any sugestions
  • Muwali Jul 23, 2008
    Thanks a lo toddg,, I will try this and Let u know the result. Thanks Again
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Sure,
    Are there 'dots' that look like round knobs on either side of the bottom of the screen bezel near the hinge?
    Worldvet
  • 408 Answers
You may be able to tighten the hinges but usually they would need to be replaced.
Posted on Jul 31, 2009
My acer Laptop 5610Z on the start-up has a white screen i can hear the signals as if it has started up but cant see anything only a white screen?
You can try to connect it to an external monitor using the vga connector on the side of the laptop.
If that works, try and hold down the function button and press the F8 key. That should switch between the two screens. If the Laptop screen still does not come on, It is probably bad.
May 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
"no signal" sign on ACER AL2423w monitor
If you get this issue frequently and it gets resolved, the most likely cause is loose cable connection from the monitor to your system.
This message means that your monitor is not getting any input from your computer. The other possible cause could be a loose video card on your computer.
Aug 06, 2009 | Acer Computers & Internet
ACER ASPIRE 5610z BLACK SCREEN
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Acer Aspire 6930-6771 Laptop
Screen is bright neon pink!
Did you also replace the power inverter when replacing the screen???
Feb 13, 2009 | Acer Aspire 5610-4648 Notebook
My monitor is not working hp pavilion dv2000
hook a vga monitor to the external port on the lappy use function keys to see if it is putting out a video signal if not mobo / video card may be bad if it is cable / lcd maybe bad or could be a virus
Oct 24, 2008 | HP 417035-001 - HP Pavilion dv2000 Series...
Acer laptop monitor black
if you dont have signal on your laptop screen, could be:
Broken LCD, Bad inverter, or bad graphics card.
Sep 23, 2008 | Acer Aspire 5100 Notebook
Monitor lid will not stay in position.
On most models the hinges are a pressed in, pressure brake type hinges, and when the hinge start getting worn to the point of not holding the screen, then they can only be replaced in order to fix it. You can sometimes get away with replacing just one. On some models there are screws on the hinges that come loose that can cause this. The screws aren't for adjusting, they are basically just set screws. You won't know which is the problem until you take the covers off. Most likely you're going to have to replace the hinges. Try Ebay for the replacements.
Aug 01, 2008 | Acer Aspire 5100 Notebook
White turns to pink on acer laptop
I had the same problem but the white color became cyan.
I "solved" the problem hiting the back of the monitor. I think that is a problem of contacts between the signal of the monitor and the pc.
I have an acer 5610z.
Juan Pablo.
Jul 28, 2008 | Acer AL1916B 19" LCD Monitor
Acer 5610z
i assume your laptop is Aspire 5610z.
try to check in device manager first.
is your camera is detected in device manager ? it should be under imaging device.
if it not detected, mean something wrong with your camera.
if it is detected, checked the manufacture.
if it is microsoft, it's mean wrong driver. it should be bison, suyin or logitect. in this case try to install the correct driver.
you can download the driver and application from www.acerpanam.com
May 27, 2008 | Acer Aspire 5100 Notebook
MY LAPTOP IS ON AND NOT SHOWING ON THE SCREEN
hi, check the RAM, remove it and clean the contacts, if still no sucess then check it with another Working RAM, this will confirm if the RAM is BAD,,let me know..dont fall prey to the non-qualified engineers (i.e ur comp person)
Mar 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
159 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
