Question about Nikon D70s Digital Camera
How can i add frames
In the photoshop?
  • Allan Noyes
    Allan Noyes May 11, 2010
    Hey sapir0608,
    What do you mean by adding frames?
    Sincerely,
    Allan
    Go Ahead. Use Us.
    Genius:
  • 2,985 Answers
Plug camera into computer and make sure it switched onto upload
If a Windows computer the Camera/Scanner Wizard will come up andfrom there you can direct images to a suitable location -My Pictures say.
Also with the camera switch on - the computer reads this as another drive.
So in Photoshop click on File/Open and direct it to the new drive..
Posted on Jul 23, 2008
    Champion:
    Scholar:
  • 216 Answers
Try to be clear, we have no ideal on what you're talking about?
Seriel number photoshopcs2
Hey i found this great new site offering Adobe Photoshop Cs2 serial numbers, here's the link:
Adobe photoshop cs2 serial numbers
I hope this will help
Jun 03, 2011 | Adobe Photoshop CS2 for PC
Tip
Banner removal from AVI using Donald Graft's Logo Filter and Adobe Photoshop
This excellent Logo Filter is usually use for adding rotating logo's to the corners of AVI files but I have found another great use if you are a bit of a wizard on Adobe Photoshop.
You can save the output frame in VirtualDub as a BMP using CTRL+2 edit it in Photoshop then overlay your edited BMP's back into the frame that you exported it from. It will take a long time to do this I have done 10 frames and the results are here I took me about an hour to create the 10 bitmaps and set the filter up correctly but the results are clear.
The Starting Frame is 61642 and I have created 10 bitmaps that start at 0000.bmp through to 0009.bmp as the origin of X:Y=0:0 for Duration of 1 frame each and loop once as you are replacing the full frame the transparent colours are not used and greyed out.
I suggest that you download his Rotating Earth and latest Logo filter and give it a go, the Earth can be made transparent (remove the back square) and last the whole AVI rotating once each frame forever using these settings.
http://neuron2.net/logo/logo.html
NOTE: There are a total of 75 bitmaps, this will give one per frame starting at frame 0 if you want the earth to rotate slower increase the Duration by the desired number of frames. If you set this to 0 one frame will last the entire AVI length (so it won't rotate)
I will post my resultant AVI's very soon until then I have upped this screendump from VirtualDub to show you how good this method is if you have the time!!!
Here is a screendump showing the same frame when processed using the best alternative quicker method Delogo Removal (no longer being developed) it gives an acceptable result. You can also use several instances of the filter across different frame sequences so you can get the best results possible. By changing the Pixel aspect ratio and Power.
This filter real comes into its own this semi-transparent logos when you can use the DeBlend Masks that you can also create using Photoshop check out my tip on how to do this HERE the Logo Removal filter with UGLARM is discussed in this tip as another alternative this one you can't specify a range of frames and has to be added for the full AVI, come on Krzysztof Wojdan lets add this function to improve your filter.
WHAT IF YOU HAVE TWO RECORDINGS OF THE SAME BROADCAST
If you have the two AVI's of the same broadcast with logos banners in different places then you can also use this Filter and Adobe Photoshop to overlay BMP's
Covering the grey hatch area over the scrolling banner on the AVI using Donald Graft's Logo Filter with specific frame reference, I have included a 50% transparent mask to indicate the area masked for use with the DeLogo Filter. When all AVI's are created then use TMPGEnc v4.0 Xpress to combine all into one (VirtualDub Append AVI only works if the file audio is the same).
In the screendump belows I used a combination of DeLogo and Graft's Logo to make it easier (DeLogo works great on solid colours if you get the red mask, pixel aspect and power just right it will move it to a 99.8% success.
The 3 seconds (highlighted in YELLOW) on this join using Logo filter v1.7b2 took about 6 hours to complete the bitmaps with Photoshop (only 30secs to encode the new AVI segment with VirtualDub) the BMP's and frame settings for each change means (the nature of AVI's means that even at 25fps where the frame changes ever 2 frames it sometimes changes 3 then back to 2 or even upto 4) the animation check box can't be used which would make this so much easier. Also using one PSD for all the BMP's makes it easier to track the changes using a guide as a reference point to line up the BMP's also use drag or paste to stack the BMP's like in this example.
on Feb 27, 2010 | Philips DivX DVD Player
Autherization code of adobe photo shop cs2 serial
100% works!!! use keygen!!!
keygen cs2: http://www.dailytipz.com/wp-content/uploads/2008/12/adobe_photoshop_cs2_keygen.zip
For Adobe Photoshop Cs2
Note: Don’t Close This keygen
Note: Don’t Click Generate Serial Number
Open Adobe Photoshop keygen befor when you Install Adobe Photoshop Cs2.
Add This Serial Number When You Install
After installation active adobe photoshop by phone
Abobe photoshop display a activation number
Add activation number in adobe photoshop kengen
Your Authorization Code Display in Adobe photoshop kengen Authorization Code menu
Copy This Code And Past into your Software
Your Work Is Commplete Enjoy Adobe Photoshop Cs2.
You can see how it Work see this pic.
Apr 23, 2010 | Computers & Internet
I missed my keygen
Apr 20, 2010 | Adobe Photoshop CS2 for PC
Even with standard window mode on I get a black frame around file
Try this:
  • Quit Photoshop
  • Rename your Photoshop Preferences file in Library > Preferences
  • Start Photoshop
Your settings will all be rest to the factory default. If you don't like this, you can always rename your Preferences file back to the original name.
Aug 03, 2009 | Adobe Photoshop Extended CS3 ( Macintosh )...
Free download actions for photoshop for photofraim to use multy photographs
try googling or try using OnOne PhotoFrame Plug-in. It has a lot of built-in frames. if u want it free search torrent of it.
Thanx
SMB
Jun 04, 2009 | Adobe Photoshop 7.0 for PC
2d Animated Frame
If you're using Photoshop, you can do so with an animated GIF image. Here's a tutorial: http://www.tutorialized.com/view/tutorial/How-to-make-an-animated-gif-image-only-on-photoshop/31955
Feb 07, 2008 | Adobe Photoshop 7.0 for PC
Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
Dec 11, 2007 | Cameras
Writing edited jpegs to CD1000
The problem is an incompatibility between Photoshop and Sony JPEG files. (I thought JPEG was supposed to be a standard!) A simple workaround is to use the PictureGear program supplied by Sony. Use its File – Process command to save the Photoshop frames to the CD-R. It is also useful to ensure that the frames are resized to 1600x1200, 1024, 640 etc to eliminate the black border that would otherwise be displayed by the camera. This “feature” can be useful however if you have frames that have important sections at the edge of the frame. This would often be lost when displaying on a TV. Save the frame as, say, 1520 x 1140 and you will always see the full picture! Another possible advantage is to use achieve greater JPEG compression. The CD1000 will accept PictureGear at the largest filesize (10) but one can use compression 8 or even less and get many more frames on a disk. There is a little loss of quality but much less than resizing down to a smaller image size. I would guess that the above will also apply to memory stick.
Sep 13, 2005 | Sony Mavica MVC-CD1000 Digital Camera
Nikon D70s Digital Camera Logo
23 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
