Question about Panasonic CQ-VD6503U Car DVD Player
Your deck did you ever figure out what was wrong with your panasonic indash? it was shuttingf down every 10 minutes, mines doesv the same... any help??? alloz775@yahoo.com
  • angelpapi007 Oct 12, 2008
    my unit the same thing, i came online to see if there was a soltion...i can see this is bs already...i will probably buy another unit..thanx...if any 1 does have a solution please chime in.
I've sent it to Panasonic Service Center but I've made my decision to buy a new branded indash by JVC. It's good till now but this one doesn't have a touch screen.
Posted on Jul 27, 2008
I have indash raido and it uts a E1 code and ejects cd how do i fix
Depending on how old your deck is, The lazer eye is probaly hooche ,End willnot read the (Disc) Info, That is what causes aE1 Code,You are better off just to get a different deck,Then have it (Repair) Cost of ( Replacing) the lazer, Can range from $180 to $290. depending on the deck.
Oct 04, 2012 | Panasonic Digital AM/FM Car Stereo...
My 10 year old tv goes off after about 5 minutes and the blue
Any colors mis alignments R,G,B.The tv have a problems known as convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced in the tv convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My memory wont work after 5 minutes or truck shut off but will after a minute or less
Are you positive that the yellow (memory wire) from the Panasonic (use a test lamp or meter) is continuing to get power after you turn off the truck and wait 5 minutes? And the Black ground is proper ... If so then it will likely cost more to repair the deck than replace it. Or you could wire the red wire to the same place the yellow wire is wired to ... then just remember to shut it off when you leave the car (or suffer a dead battery 12 hours later) ... and it won't cost more that the cost of a couple crimp connectors to do that ... the frugal way.
May 13, 2009 | Panasonic CQ-C1300U CD Player
Any progress???
EL RADIO modelo CQ-VD6503U FUNCIONA PERFECTAMENTE POR 10 MINUTOS LUEGO DE ESO APARECE ( SEE YOU) Y SE APAGA TENGO QUE DESCONECTAR EL EQUIPO PARA QUE SE VUELVA A PRENDER .
LE AGRADEZCO DE ANTEMANO SU RESPUESTA GRACIAS
Jul 22, 2008 | Panasonic CQ-VD6503U Car DVD Player
PANASONIC LCD PROJECTOR MODEL # PT-AE900U
The manual says that it will do this as a reminder that it has ended the recommended lamp life (on mine PTAE900E this starts at 2700hrs and supposedly can blow from then until the max of 3000hrs)
sounds scary enough i guess but they put that 10minutes on/off thing in there to kinda force you to get it changed...
mine is at 2600 anyone know of a good place to get a new lamp in melbourne australia?
cheers dave
Jul 13, 2008 | Panasonic (ETLAE900) Projector Lamp for...
Panasonic CT-27G34A screen jiggles/glitches up and down slightly
Sounds like dried up cap either in vertical circuit or power supply.
Apr 27, 2008 | Panasonic CT-27G34 27" TV
Plays for a minute or two - then just shuts itself off
Mine will intermittently record only the first minute or two of a tv show I have queued up to regularly record. It seems to happen anywhere from every show to every 5-10.
Mar 04, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic CQ-VD6503U Car DVD Player Logo
89 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
