I was uninstaling some programs and accidently uninstalled the sound device on my computer, and it did not have a copy of windows for me to reinstal it from. I am running winxp
  • 979 Answers
Try the restore function...accordianman
Posted on Jul 23, 2008
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
Cannot uninstal fix it utilities 10
You can go ahead and install the program revo uninstaller pro using the link http://c464521.r21.cf0.rackcdn.com/RevoUninProSetup.exe
Using which you can go ahead and uninstall the fix it utilities program from your computer, you need to select the hunter mode and point the short cut icon, if the program is not listed under the uninstall option in revo uninstaller.
Jun 18, 2011 | Avanquest Fix-It Utilities 10...
How do you uninstall a program from a palm treo 750?
You need activesync
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx
ActiveSync’s Tools >Add/Remove Programs screen lists all the programs that have been installed on your device. To uninstall a program, uncheck the box next to it and click on OK. To reinstall a program, click on the empty box next to it and click on OK. Do not click on the Remove button. Here's how to do it: If you used ActiveSync to install a third-party program to your Windows Mobile device, you can uninstall the program quickly from your PC.
  1. Make sure your Windows Mobile device is connected to your PC and ActiveSync is running.
  2. From the PC’s ActiveSync Window, click on Tools >Add/Remove Programs. This opens the “Add/Remove Programs” dialog box, which displays a list of third-party programs you have installed on your device.
  3. To uninstall any of the checked programs, click on the box to uncheck it and hit OK—ActiveSync will do the rest.
Reinstalling programs you’ve uninstalled Once you’ve installed a program using ActiveSync, the necessary installation files are saved on your PC. If you uninstall the program as described above, you can use the Add/Remove Programs menu to reinstall it at a later time. Uninstalled programs appear in the Add/Remove Programs list as items with unchecked boxes. To reinstall it, click on the check box next to it and hit OK. ActiveSync will reinstall the program automatically. Note that files in CAB format can be downloaded directly to a device and installed, so they will not appear in the Add/Remove Programs list. In addition, some freeware programs are installed by using ActiveSync’s Explorer to copy the program file to your device. Those also do not appear in the Add/Remove list. WARNING: Do not click on the “Remove” button at the bottom of the Add/Remove Programs screen unless you never again plan on using the program. This completely removes the necessary installation files from your PC and you won’t be able to reinstall the program by checking the box.
Jan 08, 2010 | Palm Treo 750 Smartphone
How do i reinstall the driver/software for my TH1101 LYRA RCA MP3 Player?
1>if u want to uninstall the software u can do it through control pannel add remove software like we do for all the programs..
2>if u want to uninstal the drivers the connect ur player in the usb>right click ur my computer>manage>device manager>usb ports>there will be ur device listed >right click it and go to properties>uninstall or reinstall the drivers from there....
cheersss...pls rate
Jan 05, 2010 | RCA TH1101 MP3 Player
How do i uninstal Windows Defender,and then reinstal
Go to Control Panel ---> Add or Remove Programs. in that check for the "Add/Remove Windows Components" . In that select the components u want to install or uninstall. But do remember if u want to reinstall the software u require the OS Cd or else the I386 folder which can be found in the Operating System CD.
Oct 26, 2009 | Microsoft Windows Vista Home Basic Edition
Will not reinstall comes up with an error in french
there is a program named revo uninstaller that will help you remove the program and scan for any remaining information after the uninstall. . Run this program and uninstall the game with it. Then run an advanced scan and delete any items it finds. then reinstall your game. It worked for me, I hope it works for you.
May 06, 2009 | Ubi Soft Entertainment CSI: Dark Motives...
I think this program was uninstalled by accident
in device manager
if you see the driver click to update or install
if you can't see it then in add hardware
click audio or sound
follow instructions a box may appear showing the device if so hight light and next if not then
choose option yes to automaticcally install
also you could shut down and remove audio card restart shutdown again reinstall card the startup again the add hardware should automatically install
but i would do this unless it was absolutely neccesary
Feb 21, 2009 | Dell Computers & Internet
Accidently uninstall my webeye driver wat shal i do now?
Rt click "my computer" go to properties, go to device manager, against imaging devices slect the webcam and uninstall it. Close all the windows and restart the computer and the computer will automatically reinstall the driver that was once installed
Jan 08, 2009 | Computers & Internet
I have a windows xp and i just baught a hp officejet j3600 printer and i can not install the printer
If you plug in the printer before you installed the software it may be the problem. Uninstall the software and then unplug the printer and then re-install the software and only plug in the printer when asked to do so. Here is instructions from the manual.
Uninstall and reinstall the software
If your installation is incomplete, or if you connected the USB cable to the computer before
prompted by the software installation screen, you might need to uninstall and then
reinstall the software. Do not simply delete the device application files from your
computer. Make sure to remove them properly using the uninstall utility provided when
you installed the software that came with the device.
There are three methods to uninstall the software on a Windows computer, and one
method to uninstall on a Macintosh computer.
To uninstall from a Windows computer, method 1
1. Disconnect the device from your computer. Do not connect it to your computer until
after you have reinstalled the software.
2. Press the Power button to turn off the device.
3. On the Windows taskbar, click Start, select Programs or All Programs, select HP,
select Officejet J3500/J3600 Series, and then click Uninstall.
4. Follow the onscreen instructions.
5. If you are asked whether you would like to remove shared files, click No.
Other programs that use these files might not work properly if the files are deleted.
6. Restart your computer.
7. To reinstall the software, insert the device Starter CD into your computer's CD-ROM
drive, follow the onscreen instructions, and also see Install the software before
connecting the device (recommended).
Dec 20, 2008 | Office Equipment & Supplies
Printer
Could be a driver conflict, with parts of old driver left in registry or similar. Try completely uninstaling all printer references (driver files) from device manager before a reinstall. Are you very sure your new driver downloads are not corrupt. Try downloading again to make sure. I use a little program called revo uninstaller to take all program references off my pc. It removes tiny traces left behind in the registry.
Nov 02, 2007 | Lexmark X4270 All-In-One InkJet Printer
24 people viewed this question
 Grubhead
Grubhead
