Question about Honeywell Heating & Cooling
Wife turned thermostat off during a storm i got off of work and cant get the air to come back on
  • 1,420 Answers
In the air handler unit, look for a small 3A fuse and replace it.
Posted on Jul 23, 2008
Coleman electric Furnace won't come on seems not to receive input from thermostat
There probably is a little transformer that runs the thermostat, at the furnace. If it is separate, it is easy to replace.
Nov 25, 2013 | Heating & Cooling
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
May 30, 2011 | Goodman Heating & Cooling
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
Recently, the power went off during a storm and now suddenly my thermostat stopped working. I changed the batteries and it worked, but now I'm changing it every couple of days. The batteries used to be...
Hello
You have lost your a/c power to your T stat.
Have a look in your fuse/circut breaker box for a blown breaker and reset it.
You may need to have your heat unit checked for a blown low voltage fuse also.
Nov 08, 2010 | Heating & Cooling
Hi, my problem with tv emerson plasma 42 etv4206pdp it does not turn on, after rainy and lighting day. i check the main power area and cant find anything grong. i dont know what else to do. if you had a...
It might have been blown out by the lightening storm. that happened to two of my tvs that were plugged in during a lightening storm. they both, and two dvd players, would not work after, but the ones that were not plugged in were fine. You should unplug your major electronic equipment during a storm, unless you have a power surge plug/equipment.
Oct 04, 2009 | Emerson EWL3706 37 in. LCD Television
My maytag m7y12f2a stopped working is their any reset buttons
All devices that have circuit boards or digital displays need a surge protector or turn off during storms. If none of the functions or dispays don't come up, there may be an inline fuse on the panel. More than likely the board or transformer is fried. For that you need a Tech.
Jul 09, 2009 | Heating & Cooling
Heater/ac unit does not work after power surge during storm. Thermostat still works.
there is usually a built in delay if power in interupted.Usually 5 minutes.
Aug 05, 2008 | GE Heating & Cooling
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
I think my router got fried during a storm. it will not turn back on. will it not work again and its a wireless router d-link 624
If your router got fried during a storm, then its not going to come back on. So, its basically useless now. You will have to out & by a new one.
Jul 31, 2008 | Computers & Internet
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
