I have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Where is the location of your amp? Try to keep amps in ventilated areas so the heat they produce can escape. If its not that then it might be your fuse, make sure you have the right fuse, sometimes if your fuse isnt strong enough it will cut off before it blows the fuse, these amps have a circuit limit as a kind of protection from blowing your fuse.
Please let me know the actual model of the amplifier.
