Re-Connection Thanks for the help I got the adapter but only the terrestrial channels are visible all the other channels have an '$' beside them and are listed as scrambled. Will my receiver need resetting?
  • normsk Jul 25, 2008
    Thanks for your help. I'm up and running
    Scholar:
  • 135 Answers
Sounds like you need to input the latest key codes and / or turn on the EMU.
To keep up to date with the latest key codes I use the free toolbar from http://thechatterbox.cc download it, install it to your browser and click on the key for the latest codes.
Posted on Jul 23, 2008
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
Is there a non-90 degree adapter to allow me to view terrestrial objects without the image being reversed on the edu science 50-360?
yes, and a 45 degree one also-- they are called an "erecting prism diagonal". Like this one:
http://www.telescope.com/catalog/product.jsp?productId=7216&utm_source=channeladvisor&utm_medium=cse&utm_campaign=Channel%2Badvisor&CA_6C15C=245938822
Dec 25, 2013 | Optics
I have mislaid my instruction manual for my Philips HDT8520/05 Digital Terrestrial Recorder, and would like to locate a copy ASAP.
Click here and download the user manual in PDF format. Beside this all the other support is also available at link.
May 13, 2011 | Televison & Video
I cant receive freeveiw channels
I don't know what make of TV you have but some manufacturers have two tuners at the rear of the TV. One for terrestrial signal & one for digital signal. If this is the case put the aerial into the digital input & try retuning. If this does not work then if you could provide the details of you TV eg. make & model, then I will try to help you further.
Jun 29, 2009 | Televison & Video
Problem with 2Wire 802.11g Wireless USB Adapter
Were you using a different wireless adapter prior to the USB version you now have? Here is where I am going, It may be using the settings for the old network adapter.There could be a redundancy, this happens all the time, the best way is to start from scratch. Just use the wizard to establish a new connection. You may see the old connection while doing this, in which case I would delete it. If you rt click on my network, the icon on the desktop, and select properties, it will walk you through a new connection, this way you know that you are starting from scratch. Good luck, and let me know if this doesn't work for you, we can eliminate the obvious and look deeper, make sure to put the same encryption and key in when you set up good luck
Mar 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Can only recieve terrestrial channels
new codes .
N*l .
0=31 6F CB 3F 2E 45 5A 04
1=EA B7 BF B2 D5 AA 46 AB
Tw.
0=04 4D 6F 7D D5 C9 F7 9B
1=16 CF 0C A7 A7 14 D2 22
cw.
0=85 AF 58 1A 36 96 B6 C9
1=B5 8E A1 3E 6F D7 BD D2
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cannot find network 1394 network adapter nor the standard Network Adapter connection
Try having a System Restore on your computer back to the date before you installed the wireless HP printer device and software.
Sep 13, 2008 | Computers & Internet
No av5 in menu
it becomes visible after you hook up a dvi to hdmi adapter
Jan 01, 2008 | Philips 51PW9363 51" Rear Projection...
78 people viewed this question
 Grubhead
Grubhead
