Question about Toshiba Satellite A135-S4467 Notebook
Powersaver problem i have a laptop and when i start some times it shows me power saver has stopped working if u can help me to remove this error please thnaks
  • nilampatel Jul 23, 2008
    it didnt help me please can u send me another solution please i m worrying about it.
  • 781 Answers
Right click on desktop go to properties/settings/advanced check on power saving settings
enter BIOS on start up check how power saving setup
Posted on Jul 22, 2008
  • David
    David Jul 23, 2008
    why inappropriate I gave a solution according to your question if it was not correct perhaps you should have asked the question different at least it should have been helpful
    My answer gave you something to try which may have done the job
    There is one other thing to try
    go to C:\ right click properties/tools/check now when box pops up tick box to repair any faults reboot when windows reboots it will scan you system and registry files and repair any faulty ones. as sometimes this causes unseen problems
Disable power saving mode
Sorry, but you will NOT be able to DISABLE the power saver mode on this printer. The printer will still go into "power saver mode", but it takes longer to do so, if you set diffrent as default time delay [ Two power saver modes: (1) print to standby mode 35 Watt, user-definable 1-30 minutes, default 3 minutes ; (2) print to powersaver mode 4 Watt, user-definable 5-60 minutes, default 10 minutes ].
See also:
Dell 1250C problems with sleep mode
Oct 01, 2014 | Dell 1320c Laser Printer
How do i get it to stop powersaver at start up
its not the monitor.. it is your computer's power saver option. If you are using XP, start--->go into control panel----> power options and there will be options for different thing... find where it says turn off monitor after 15 min and make it to any time you want. Also same in vista and windows 7..
Good Luck
Nov 28, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
How to stop my laptop from turning off when I am watching or reading something
1. right click on an empty spot on your desktop-select properties. select the screen saver tab-using the drop down arrow by the screensaver box change the screensaver to "none", click apply.
2. while at the screensaver tab, click on the "power" button- click on the down arrow on the right side of the Power Schemes box and select "always On"- click APPLY and OK
This turns off your screensaver and power management for continuous play of dvds or extended reading time..
you will have to yurn off the monitor manually if you leave the computer running all night as it wont auto powersave now...
Jun 28, 2010 | Samsung R530 Notebook
Power saver problems
Did it come out of power-save mode when you connected it to the other computer?
Does your laptop have a "toggle":
* video-output only to internal LCD screen
* video-output only to external monitor
* video-output to both displays
If so, toggle the setting to "external" or to "both".
Dec 14, 2009 | LG W2252TQ Monitor
So my computer games have been lagging way too much. I use an HP laptop pavilion to play certain games like Call of duty, Crossfire, etc. and all of the games get around 20-30 FPS. What's weird is that...
My guess is that the laptop gets hot and then goes into a powersaving plan to reduce heat production, as a sort of overheating protection. If you want to stop this, run the game on a better cooled machine (dekstop PC) or get a laptop cooler.
Dec 03, 2009 | Activision Call of Duty 4: Modern Warfare
How do i remove the icons from the screen so i can see myscreen saver
You can enter the phone settings and switch off the standby applications mode.
Oct 31, 2009 | Nokia N95 Cellular Phone
Hp 4100dtn powersave issue
I see that your machines are not on a network but do they have network cards installed?
The jet direct card can cause various problems. Look to see if they are in your machines and remove them if they are.
If that doesn't work you can print an event log and see if any errors corespond with the condition.
Hope this helps
Jan 12, 2009 | HP LaserJet 4100dtn Printer
Nokia n72 screensaver activation.
You need activate it under
Themes->Power saver->(Select a theme)
You can preview it under
Themes->Power saver->(theme)->Options->Preview
Aug 20, 2008 | Nokia N72 Cellular Phone
Toshiba Power Saver
It sounds like the built in powersaver utility is crashing. Assuming you can log into the OS after the error, go to Control Panel - Power Options and change to some other (or none at all) setting. And/or uninstall the application completely.
If you can not even get into windows you could try changing the power settings within to bios to disable power saving at all, and that might allow you to boot properly and then turn off/uninstall as described above.
Jan 16, 2008 | Computers & Internet
Power saver error 0x5
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
Dec 10, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A135-S4467 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
