Question about Compaq Evo N610C Notebook
Screen won't display
Hello, I have a compaq N610c. When I put it on the screen displays for a second or two and goes blank even though the laptop still remains on. How do I get to rectify this problem
  • 2 more comments
  • Evans Nguma Jul 22, 2008
    Thanks! that was fast. I tried pressing F10 and no response. I also tried hooking up a CRT monitor to it but could not get it to display. And yes, I know how to dismantle to an extent.
    The Big E
    Thnks a million!...I will try it out when I get home today.
    A sorry to bother you, I also have a second problem on the same laptop. The battery does not charge and the charging light indicator does not come on when plugged to A/C. The battery is okay cause I've tested it with another laptop. What do I do? Am grateful.
    - Evans
  • Evans Nguma Jul 24, 2008
    Hello Worldvet, thanks for your assistance. I was able to removed the cmos battery for a few minutes and put it back. but the screen still behaves the same way (i.e. comes on and goes blank). But I haven't reset the time and date yet cause the screen is still blank and the battery won't charge too.
    What special action should I take. The system is Compaq Evo N610c PP2040. Kindly assist.
    Thnks
    Evans
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you tried tapping the F10 key to access the bios setup screen during the brief period you have a screen?
    Have you tried hooking up an external display to your laptop's blue connector?
    How handy are you with taking apart things like a car, a chainsaw, a lawnmower a motorcycle? You get the idea? A laptop can be reset but require it be disaseembled somewhat. I need to know how comfortable you are at this. Are you?
    Let me know, okay?
    Regards,
    Worldvet
    Guru:
  • 859 Answers
Ok, good. Hold on a minute I'll be back.
Posted on Jul 22, 2008
  • 2 more comments
  • Glenn Rogers
    Glenn Rogers Jul 22, 2008
    Shut down the laptop, remove battery and A/C power, close the screen. Turn the unit over. There are screws accessed from the bottom. Sometimes, there are letters on the bottom that say "keyboard". You want to remove these screws. Once you do so, turn the unit back over, open the screen and then remove the wrist rest top and the part that goes over the keys. When this lifts off, do so carefully as there is a ribbon cable from your keyboard to the motherboard. Be careful not to pull this out or loose.
    In the inside you will see a battery pack or a coin battery that connect to the keyboard with a white connector. This connector has two wires, usually white and red. Pull this gently away from the socket it is in. Leave this disconnected for a few minutes. This should reset your computer. Push the plug back into place reset the wrist pad and keyboard bezel, close the lid and turn the unit back over. Screw the unti back together and startup now with your battery in and A/C connected. It should automatically stop and give you a press an F key or F1 to continue because the time/date has changed. Go into the bios with the F key and set the date and time, set the pointer to mouse only or serial if you use a mouse and you should be okay.
    Worldvet
  • Glenn Rogers
    Okay. take it slow and easy on removing the keyboard.Sometimes there are locking tabs that need to be eased loose. They can make a really loud crack when they come loose, but more so when you put it back together. Don't let that unnerve you.
    Careful with the wrist pad lift off because of the ribbon cable.Should that come apart. Post back to me and I'll explain how to reconecte it. It looks like you should be able to just slip it in but its not the way you do it right. You can find me from the home page ,Find Experts, I'm listed somewhere in the first five pages or so. Or if you can come back to this page use teh comment box. I get emailed that you posted a question.
    On the battery charging on your laptop. It could just be the laptop. But use the Ask Me button to make a request and include your make and model as well as any other IDs like a service tag. I can look up to see if there is an update for your battery charger. If there isn't one, you just may be out of luck, However, resetting the laptop this way, above, may resolve the battery issue too.
    Worldvet
  • Glenn Rogers
    BTW, I doubt this, but if you find a coin cell battery in there, use a knife to gently pry the battery out of position completely and remove it. Leave it out for a few minutes as well. Then place it in position and push into the locked placement.
    Good luck, and if you get stuck, contact me using the Ask Me button to make a new request as opposed to using the comment box below.
    WV
  • Glenn Rogers
    Glenn Rogers Jul 24, 2008
    Will you please use the Ask Me button to make a request and we can start a new thread on this. Unfortunately, some of our work here on Fixya gets spammed by the likes of DrNittin and others that are much worse than his. thanks.
    Since I know you can disassemble a laptop case this opens up the potential to replace parts that won't be the first thing we'll do next.
    Thanks. I'll look for it and get back with you later as I have my own shop to look after during the daytime.
    Worldvet
    Sergeant:
    Champion:
  • 221 Answers
You should contact Service Center.
Starts up goes to start windows then goes off and comes back to start again
It is more than likely the hard drive, or the window files are corrupted, if you have a backup recovery disc try it now, no change! have the hardware tested.
Jun 23, 2012 | HP Compaq Evo n610c Notebook
I have a Compaq 610n and when i went to turn it on today i have a blank screen, i hooked it up to tv and can use it from there , even though its not fitting on the screen right even with changing...
I suggest that the notebook screen is switched off. Check along the Function keys for a Screen Symbol and then press Fn and the F key with the symbol. (It is F5 in my case).
Hope this helps.
Nov 29, 2010 | Compaq Evo N610C Notebook
ATI vga driver and compaq N610c
plz i want compaq Evo N610c vga driver
Dec 04, 2008 | Compaq Evo N610C Notebook
Blank screen
ok this means probaly ur Operating System has crashed.
If u have a bootable OS Cd-Rom then plz notify me and then i tell u the next step.
Do not install it yourself unless you have done it before.
Jul 22, 2008 | Compaq Evo N610C Notebook
Evo n610c black black screen please help
If an external monitor works, then the LCD has failed and needs replaced.
Jul 13, 2008 | Compaq Evo N610C Notebook
Toshiba Laptop Won't Boot
try to boot from xp cd and reinstall the windows
Apr 12, 2008 | Compaq Evo N610C Notebook
I own a evo n510c
If you are hooked up the the external monitor and/or TV and can see the desktop, you can probably reselect the internal display via software from Display Properties.
In most cases you can change from the external display to the internal and vice versa by holding down the blue Fn key, and hitting the proper number on the keyboard. The correct key has a blue icon meant to resemble a monitor on it.
This is if the repair/replacment of the internal screen was done correctly and the screen is actually working. If the screen is not actually working, though, this will not help you.
Jan 28, 2008 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
219 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
