Question about IBM Netfinity 3500 M20 8657 Server
Network & Speed Problem
My IBM servicer is very slow and it shows error at startup 5962 configuration change has occured
and can't detect network
  • 2,567 Answers
I suspect that the network interface card failed, & that's why you get the error message. Try disabling it from the BIOS & see if the error message disappears. If it did, then you have a failing network interface card & need to install anew one.
Posted on Apr 14, 2009
Hello im troubleshooting a error on a dell dimension 2400, windows xp error when testing or querying the modem the error reads cannot connect or check to see if hardware is powered on or connected...
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Jan 05, 2011 | Dell Dimension 4500 PC Desktop
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Tip
Networking Issues
Problem: Network Cable Unplugged
Description: Don’t take this message literally - there are many causes besides not having a cable physically plugged into the network card. The message really means that the network card doesn’t detect a live link to another device on the other end of the cable.
Possible Solutions:
Download and install the latest network card driver program.
Check the cabling - a bad cable will prevent link detection. Substitute a cable that’s known to be good.
Check the link lights on the device on the other end of the cable, whether it’s a hub, switch, router, or a NIC in another computer. It should show a live link to the NIC. If it doesn’t, try a different port.
Auto-detecting speed and duplex mode can be unreliable. Set them manually. Most routers and switches use 100Mb, full duplex. Hubs can only use half duplex.
Problem: Renewing a DHCP lease fails, with error message “An error occurred while renewing interface <name>: The system cannot find the file specified.”
Problem: Network connection configured to obtain an IP address automatically has IP address 0.0.0.0
Solution: Make sure that the DHCP Client service is running:
Right click My Computer, and click Manage.
Double click Services and Applications.
Double click Services.
Double click DHCP Client. If the Service status is Stopped, click Start.
Set the Startup type to Automatic.
Thanks to Lightcap, who suggested this fix in a news group message.
Problem: Network Connection Has IP Address 169.254.x.x
Description: The network card is configured to obtain an IP address automatically, and it’s connected to a network with a DHCP server: hardware router, another computer running Internet Connection Sharing, cable modem, DSL modem, etc. But it gets a 169.254.x.x IP address, which indicates that it can’t communicate with the DHCP server:
Possible Solutions:
Connect the computer using a different Ethernet cable or hub/switch/router port.
Download and install the latest firmware for the hardware router.
Disable XP’s Internet Connection Firewall <../xp/ic_firewall.htm> on the local area network connection.
The card is configured to automatically sense network speed and duplex mode, but auto-sensing is failing. Configure the speed and duplex mode manually. For example, most switches and routers use 100 Mb speed and full duplex. To make the settings, right click the network connection and click Properties | Configure | Advanced.
Un-install the network card and move it to a different slot.
If you have a cable modem connection, turn off the computer, turn off the cable modem, and wait a few minutes. Turn on the cable modem, and then turn on the computer.
Error Message: An error has occurred while trying to share <filename>. The Server service is not started. The shared resource was not created at this time.
Solution:
To start the Server service:
Right click My Computer and select Manage.
Scroll down the list of services and double click Server.
Click the Start button.
Click Apply and OK.
Problem: Computer A Can Ping Computer B, but not Vice Versa
Solution: This is almost always caused by an improperly configured firewall on Computer A.
Problem: One Computer Can’t Access Some Web Sites, but Other Computers Can
Solution: Look for the Windows Hosts file on the problem computer:
Windows 95/98/Me: C:\Windows\Hosts
Windows 2000: C:\WinNT\System32\Drivers\Etc\Hosts
Windows XP: C:\Windows\System32\Drivers\Etc\Hosts
Open it with a text editor and you'll probably find lines with the names of the sites that you can't access. Delete those lines, save the file, and try again. If those are the only lines in the file, delete the file. Be sure to save it with a file name of just Hosts, with no file type. If your editor saves it as Hosts.txt, rename it to just Hosts.
The Hosts file can be created by "web accelerator" programs that store name-to-IP address translations. This might speed up access by a tiny amount, but it causes problems when a site's IP address changes.
Problem: A shared disk or folder doesn’t appear in My Network Places
Description: The disk or folder is shared correctly on another computer, but it doesn’t appear.
Solution 1: Click Add a network place and follow the prompts to add it. Browse to it through Entire Network, or specify the path name using the form \\computer\share.
Solution 2: Click View workgroup computers, then click the computer that has the shared disk or folder.
Problem: XP's Network Setup Wizard Says That No Network Card Is Installed
Solution: XP's Network Setup Wizard sometimes fails to recognize an installed and working network card. This is because the NIC's driver program doesn't respond correctly to all of the queries that the Wizard makes when it's looking for a NIC. Configure the card’s TCP/IP properties manually. Here’s how to do it for Windows 95/98/Me <../ics/icsclient.htm>, Windows 2000 <../ics/ics_win2k_client.htm>, and Windows XP <../xp_ics/clientwiz.htm>. Then set the workgroup name to MSHOME.
Problem: Windows XP takes a long time to open a shared disk or folder on a computer running Windows 95, 98, or Me
Description: This is a different problem than My Network Places taking a long time to open <slowbrowse02.htm>. This problem occurs after you double click a shared disk or folder.
Possible Solutions:
Disable searching for scheduled tasks
This Microsoft Knowledge Base article <http://support.microsoft.com/default.aspx?scid=kb;en-us; Q245800> describes a bug in Windows 2000 Professional that might also exist in Windows XP. Disable searching for scheduled tasks by deleting this registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\
CurrentVersion\Explorer\RemoteComputer\NameSpace\
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
· Delete stored network passwords
1. Click Control Panel | User Accounts.
2. Click your user name.
3. Click Manage my network passwords.
4. Click each entry and click Remove
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
Cant access wireless network
Dec 01, 2010 | ASUS Eee PC 4GB Notebook
Cannot get on the internet because of article 871122
This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then click Change settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then clickOK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
Jun 01, 2010 | Toshiba Satellite A105-S4344 Notebook
My internet speed is too slow, it only recieve 10Mbps as i view it on Lan. how can i make it to 100Mpbs? By the way my internet is connected on built-in lan (through Motherboard) do i have to buy Lan card...
So from Network Connections, you right-click the LAN connection, select status, and it displays Speed: 10 Mbps ?
If you select the Properties button from that dialog, and then with network card showing, select the Configure button; and from the properties shown on the Advanced tab, select Link Speed & Duplex. The value should be Auto Detect. If the LAN is configured correctly for 100 Mbps, you should get it.
Mar 01, 2010 | EliteGroup ECS G31T-M Motherboard - Quad...
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
I am not sure
Code 5962: An IDE device (other than hard drive) configuration error.
Things to check:
  1. Run configuration
  2. CD-ROM drive
  3. CD-ROM adapter
  4. Zip or other ATAPI device
  5. System board
  6. Riser card
Regards
Jun 23, 2009 | IBM NetVista PC Desktop
It says i am connected to wi fi internet but cannot browse it says see article 871122 microsoft knowledge base on microsoft.com please help do i need to download something.
1.) Pls. use the software for your wi fi adapter, connected on desktop to connect to the wireless lan.
2.) microsoft: This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
Apr 25, 2009 | Computers & Internet
HP DV6000 wireless not connecting and there is NO Audio at all
Try doing the following:
1.) Go to Start -> Control Panel -> Performance and Maintenance -> Administrative Tools -> Services.
2.) Scroll down to Wireless Zero Configuration, and double-click Wireless Zero Configuration.
3.) On the General tab, after Startup type, change the startup type to Automatic.
4.) Start the service by clicking Start.
Now try detecting the wirless network
Let us know if this works, and good luck!
Dec 02, 2008 | HP Pavilion dv9000z Notebook
IBM Netfinity 3500 M20 8657 Server Logo
259 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
