Targus APA01 90AC Power Adapter about 2 weeks old- adapter beeps when leads are connected?
  • shlamoof Apr 04, 2009
    I have the same problem. All of a sudden the cord stopped giving power and started beeping. It's brand new!
map9966
  • 2351 Answers
SOURCE: video adapter error in boot - 1 long+2 short beeps
For memory go to pg. 1-14 section 1.7.2, after going over these configurations go to pg. 1-15 & check your current memory against the QVL list. In regards to the NVIDIA 6150 GPU lets check the device manager & see if there is a problem. At display adapters do you see a red X or a yellow ! point? If red X the NVIDIA controller is most likely defective. If a ! point, right click & uninstall device. Before you restart the PC reinstall the chipset drivers from the Asus CD. If the problem failed to resolve you'll have to contact Asus tech EST at 812-282-2787. The tech will run you trough a quick check to be sure the controller is defective & will than give you a case number for a RMA. You'll have to ask to be transfered to the RMA dept to save you from another call. To test your memory 1 dimm at a time download this program for free CrystalMark 0.9.123.404b & check your memory.: http://www.warp2search.net/crystalmark-2004r2-0-9-123-404b-s36517.html
I hope all goes well!
please vote.....
Posted on Jan 20, 2008
SOURCE: Targus power supply TIP for HP dv2630ea
Did you contact HP?
Posted on Mar 10, 2008
ACiDFiRE
  • 45 Answers
SOURCE: MY TARGUS BLUETOOTH ADAPTER CAN
try getting to correct drivers here:
http://www.targus.com/us/support_downloads.asp
Posted on Sep 24, 2008
  • 397 Answers
SOURCE: 2 yr old toshiba satellite
As long as the output voltage from the power supply is the same as what your laptop needs your good to go, but, also check the output "amps" you need the amps rating to be the same or more on the power supply. The laptop will only draw the amps it needs so if the power supply amps rating is higher no problem, but if the power supply amps rating is lower it could cause the power supply to over heat and maybe die on you.
If you are unsure please check with someone familiar with electrical ratings.
Posted on Oct 19, 2008
  • 395 Answers
SOURCE: Power Adapter died
ebay has them $49 the part number to look for is hp-an235d43 , also try google to search for a company
Posted on Dec 14, 2008
Keyboard quit working; blue charge light on
faulty power adapter port, may have blue light meaning charger is working normally, double check with another working power adapter or use your adapter with another keyboard to check which device has problem, power adapter or keyboard port.
Oct 12, 2014 | Targus 90W AC Universal Wall Power Adapter...
Targus 4-Port not working
First off hubs don't support a lot of power hungry devices so you should be able to buy an optional power adapter for the hub on targus' site.
Second if your computer doesn't have any usb 3 ports then the hub will only operate at usb 2 speeds.
Your probably overloading the hub. Buy the power adapter.
Dec 22, 2012 | Targus 4-port USB Hub Group International...
Hp dv7 power supply beeping, wont charge
If the adapter is faulty you need a new one.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Nov 28, 2012 | HP Computers & Internet
What is the problem when you troubleshoots your computer and you unplug all peripherals except the CPU, motherbaord and the power supply was left but still has a strange beep
Check all data and power leads connecting to motherboard.
start up beeping sounds
1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Nov 23, 2012 | Computers & Internet
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
Universal power supply targus tip for Dell Latitude D620, won't charge battery, pop up says slow and no (charge), use only Dell. Is there a Targus tip that will go on Model APA10 Targus Universal power...
the problem is the BIOS of the Dell system is looking for an ID signal from the AC adapter so it knows what adapter is connected. If the BIOS cannot ID the power supply, then battery charger is disabled.
You will need to get a Dell AC adapter.
http://www.discountelectronics.com/index.php?l=product_detail&p=1459
Feb 15, 2010 | Dell Latitude D620 Notebook
No power appears to reach the laptop
Try do this... Clean Leads Once a month, clean the leads (silver or gold metal strips on end of battery) with rubbing alcohol to ensure that your battery is making a good clean contact with the leads in your system. GoodLuck!
Jun 26, 2009 | Targus (PA179U) Car Adapter
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Gateway laptop not working
What is the problem with the notebook?
Do you get any lights on the notebook when its plugged in?
Have you tried another power adapter?
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
356 people viewed this question
David Payne
David Payne
